TR2/3/3A How to check for cylinder-to-cylinder head gasket leak
Geo Hahn
Possibly, be sure to have the throttle plates wide open.
A leak down test might tell you more.
What makes you think this is happening? Seems like it could occur between 1 & 2 or 3 & 4 but those are pretty stout sections of gasket.
RedTR3
RedTR3
George,
Yes, I am working through solving the intermittent misfire issues I am having (posted about a month ago). I still have a lot of things on the forum's suggested list to work on but I am just thinking of the next step.... in case I finish the "list" without solving the problem.
TR3driver
Great Pumpkin - R.I.P
If the leak is small enough to not show up in a compression test, most likely it also won't cause a misfire. You can actually have a pretty bad leak (significantly lower compression reading) and still have the cylinder run.
But it's definitely worth running a compression test.
svtmikey
Leak test would be the best way as Geo Hahn said earlier.
pressurize one cylinder, with piston and valves position properly and you most likely will hear an air hissing noise out of the spark plug hole on the other cylinder.
If it is bad enough to cause a misfire from low compression you should.
I guess if you run a compression test and have low compression wet and dry in side by side cylinders, that might also point to it as well.
But the gaskets are pretty "stout" as mentioned earlier
Mikey
Deleted member 8987
Just start with a compression test, dry, then wet, which gives you a baseline.
I keep a sheet of paper in the back of my shop manual with compressions by date, and valve lash by date.
You have an issue with guides not allowing valve to seat sometimes, spring, cam, leakdown won't tell you issues with rotation based compression.
Been doing this what, hobbyist and professional almost 50 years, leakdown is last if the compression testS show an issue you want to pursue.
Only time I ever saw anyone start with leakdown was an air cooled VW guy who worked for me in about 1980. I just let him do it his way.
Generally he would end up doing a compression test anyway.
Worst part is folks who pull ONE plug, test that hole, put it back in, pull the next plug, and so on.
First, the engine does not spin freely enough, and head gasket leaks between cylinders will be much harder to locate.
dklawson
When we got our Spitfire as a non-running project its 1300 never ran right no matter how much tuning and tinkering I tried. I started with the compression test and found low values of about 95 PSI on all cylinders with very little spread between them. After chasing this for a while I did the leak down test. Immediately problems were apparent. There was leakage into the block, into the water jacket, and into the intake. The only place I didn't appear to have a leak was into the exhaust. Each cylinder had its own leak path and none were "good". That engine is still wrapped up in plastic sheeting with oily rags in the cylinder head ports. I will rebuild it someday but it was quicker in this case to put in a different engine and find the source of the leaks later. My point is... sometimes the leak down test will reveal things that do not show up in a compression test.
Deleted member 8987
That's what I said. But you start with compression. 95 pounds tells you something right there. It's shot.
THEN you go deeper.
Leakdown is good, but get your numbers first.
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
HealeyDave Door Check Friction Adjustment Austin Healey 12
sundown TR6 1973 TR6 door check straps Triumph 3
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
drooartz General Tech Check those brake hoses! MG 11
sundown TR6 Door check strap Triumph 3
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
