BN1 door check replacement
matt78
Hello friends of old machinery !
One small question about a (minor ?) concern...
My left door check is broken. I'm thinking of replacing the whole assembly, but worrying about the poor access to the rear side of the A-pillar.
According to your experience, do I have any chance to :
1) remove the fixed part fitted to the A-pillar, without removing the left fender / wing ? I'm afraid that it might be necessary in order to gain access to it, and
2) fit the new part, by sliding it into the hole of the A-pillar ? Even if 1) is ok, 2) could be difficult or impossible to do, due to the strap - absent for 1) because it's fallen inside :eek:
Thank you in advance for your replies.
Regards,
Matt
M
matt78
I'm pretty sure you have to remove the wing, as the bulk of the assembly is on the 'wrong' side of the pillar.
Thank you for this opinion.
I'm afraid I should, yes, even if today I finally managed to extract the broken one...
I'm going to source a replacement part, and see if by customizing its shape I might be able to put it through the hole - I know, can't help dreaming...
Matt
pan
G'day Matt, I'm pretty sure that only BN2 type door checks are available so some modification will be necessary on your BN1. The 'fenders' or wings were fitted to my car when I installed mine but I recall it was a tricky job.
M
matt78
Thank you Pan.
When I placed my order, the door check pictured on the web site seemed very similar to mine - otherwise I wouldn't have taken the risk to buy it...
This is rather consistent with your comment, as my 100/4 was built on '55, so might have the same technical definition as your BN2 in this area.
Matt
Joe_Healey
Member
I ordered mine from one of the British places. On their web site they had the door checks reversed. The BN2 has a rubber buffer the BN1 does not. I hope this helps.
Joe
Lambdaman
BN1's had two types of door check stays, only in recent times has the very early type become available, as the cars get older parts it seems are becoming easier to source
M
matt78
Job done.
I finally managed to insert the new part through the (not so) big hole of the pillar - while securing it with a wire, in order to prevent it falling into the fender...
No modification was necessary because - I suppose - my car is a late BN1, and the part is fitted with the rubber buffer.
Thank you all for your information.
Matt
busybrit
Wish I'd read this post a few days ago, may have saved you some time.
My car is an early BN1 with the hard to find door checks. I tied a long piece of string to the original part then removed the screws. It dropped to the floor taking the string with it. I then replaced the original part with the new part, and pulled the other end of the string until the door check was in place.
Johnb
... My car is an early BN1 with the hard to find door checks. I tied a long piece of string to the original part then removed the screws. It dropped to the floor taking the string with it. I then replaced the original part with the new part, and pulled the other end of the string until the door check was in place.Johnb
Clever! I'll remember that one.
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
Dougal BN1 Door trim patern required Austin Healey 3
T Door Adjustment on a BN1 Austin Healey 8
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
55modified Nardi hub for a BN1? Austin Healey 10
L BN1 Transmission rebuild Austin Healey 1
