Weber 40DCOE - Does it need a check valve in the fuel supply line?
DanLewis
I've noticed that if I pull the starter immediately after turning on the ignition, it takes several tries to get the engine running. However, if I turn on the ignition (and thus the electric fuel pump) and then wait about 10 seconds before pulling on the starter, the engine starts right up and runs fine. That makes me think that it needs time for the fuel pump to fill the fuel bowl in the carb - i.e., that the fuel bowl somehow drains or evaporates overnight. I haven't found any leaks, so I'm wondering if somehow when the engine is turned off, the fuel is being drained backwards out of the carb and down the fuel line towards the tank?
Has anyone else ever noticed this with a Weber sidedraft carb? (Mine's a 40DCOE.) Would putting a check valve in the fuel line just before the carb solve it, or is this due to fuel evaporation from the bowl?
Dan
G
No idea, I don't want mine to start right away anyway. This is a good thing, go with the flow and build up oil pressure before it lights off. :wink:
DanLewis
DanLewis
Thanks for the suggestion, but it seems to me that as far as building up oil pressure first, it really doesn't matter whether the initial turning over is due to the starter or to combustion. Right?
Dan
bugedd
Mine did the same thing, especially if the car sat for a week or more. I'd let it prime for about 7-8 seconds, then it would fire right up.
G
Thanks for the suggestion, but does it seems to me that as far as building up oil pressure first, it really doesn't matter whether the initial turning over is due to the starter or to combustion. Right?
Dan
I'll let you answer that: Which do you think applies more pressure and force, 200#s of compression or an air/fuel explosion?
The idea of pressure "lubrication" is not only to lube but provide a film for the bearings to "water ski" across. I'd much prefer my bearings under full possible lubrication before maximum low speed load is applied.
scubabatdan The Saga continues 40DCOE weber Spridgets 8
scubabatdan Help! Weber 40DCOE throttle problems Up-date Spridgets 56
hondo402000 TR6 TR6 Weber 40dcoe HELP Triumph 5
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
W Weber/stromberg air cleaners Jaguar 3
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
