MGB Which Weber DGV is the right one.
Coastalman
I have had many British cars, but never one with a Weber on it. The '77 B I just bought has one, a down draft DGV. It is fouled up from old gas and never changing the filter. In looking for a new one, I see many on Amazon, but I don't know what I should be looking for. I am told that the electric choke is the way to go. I have the manifold for the down draft that can be reused. If anyone can tell me which Weber I should order I would be very grateful.
Thanks,
Charlie
Mickey Richaud
If you just want to replace the Weber, the 32/36 DGEV is the one you want.
However, check into swapping out manifolds and going with twin SU's. It'll cost more, but will open the 1800 up.
C
Coastalman
Hi Mickey! I thought I would try using/having a Weber just to round out my LBC experiences. I have the SUs on my MGA and they are doing a great job. I have two extra B carbs on the shelf so I can just find a manifold and linkage at any time to convert the fuel system. I see the 32/36 DGEVs on Amazon, but they don't say which configuration is for the B. That is the direction I am hoping the Forum can guide me in.
Charlie
Mickey Richaud
By the way the DGV on the B now has a manual choke, but I'd like to get away from that.
I believe the DGEV is simply a DGV with manual choke. The only variables would be the jets, which are available in kits. I've never used a Weber on a B, so don't know the proper sizes; maybe someone else will chime in with their numbers.
And be sure the DGEV from Amazon is a Weber and not a knockoff - lots of those listed.
Oh, and if I'm not mistaken, if you do go with SU's, you'll also need to swap out the exhaust manifold.
C
Coastalman
True. Mickey, my confusion comes from lack of knowledge and the different configurations I see listed for the Weber on Amazon, Ebay and other sites. The Weber on my car must be an old one because the new ones seem to have fittings in different places. I think I'll just wait for a friend of mine to get back from his summer travels at the end of this month. He has rebuilt Webers and can give me some insight on what I'm trying to accomplish. I think your suggestion of going to SU's is probably going to be the best option. I am familiar with those.
I did see the knockoffs and wondered about them. It's always the best choice to go with the original if possible.
Charlie
YakkoWarner
There are times when you don't have to replace the exhaust manifold when going to SUs, - it depends on how well it lines up with the original faqctory style intake the SUs use. If the thick washers that bridge between the intake and exhaust are perfectly parallel to the face of the head, then its fine. If the exaust manifold is thinner or thicker than the SU intake, then you have to either swap it out or modify it.
PAUL161
At one time, one could buy 2 stage flat washers of different thicknesses to make up the different thicknesses of the manifold flanges and keep everything in its proper perspective. I've made a couple of sets. PJ
YakkoWarner
I hadn't seen those. I have had a 3rd party header that had small squares of steel stock welded to the flanges to make up the difference in thickness, that worked well.
zykcon
Bronze
Hi Mickey,
if you are looking to purchase a new Weber DVG 32/36 5A manual choke,I would not suggest buying the ones I have seen on Amazon. What you are looking for is one made in Spain, these are the “real ones”. I recommend Pierce Manifolds, or Redline Weber. I would also suggest changing the choke cable, which are available from Moss, Rimmer Bros. Etc.
I rebuilt mine with great results, so if you decide to rebuild I recommend the more comprehensive re build kit. Also there are very good service centers who could do it for, All State Carburetor in NY is one.
cheers
Mitch
C
Coastalman
Mitch, where is the best place to buy the rebuild kits? I had the car running today, but only with the choke pulled all the way out. It ran at just under 2K rpm until I shut it off. If I push the choke in, the motor stops running.
Thanks,
Charlie
Tybalt
The DGV family is a progressive two barrel carb with three primary subsets, the DGV with manual choke, the DGAV with a water choke and the DGEV with an electrical choke.
What you run into these days is a limited number of Weber models within any of the basic families. There used to be many different DCOE, DGxV, IDF, etc models available within those families but now it is down to just one or two within a given size within those families so tuning a newly purchased Weber is a bit trickier. Seeing that the DGEV model currently listed in the various Redline MG conversion kits is the same for everything from the early 1500 MGAs and 1500 Spitfires (Triumph engines) to the 1800 cc variations on the BMC "B" seried engines used in the MGB, I would not be surprised if a little jet swapping around wouldn't be in order. At least it's not like say a DCOE where ventiris get tossed into the mix as well.
In addition to the Redline and Pierce mentioned above, I would also throw Pegasus Racing into the mix for new carbs and/or parts. It will be important that whoever you deal with have someone on staff that can help you out with questions on set up and jetting suggestions based on the exact carb model that you have if rebuilding or if fitting new any possible jetting changes that might be in order based upon your specific vehicle application and altitude.
Best wishes on the task at hand
C
Coastalman
Great information Tybalt! Thanks for it. I went to the Redline website over the weekend and thought I might give them a call. Now I can add Pegasus into my information gathering.
Charlie
zykcon
Bronze
Thanks,
Charlie
Pierce Manifolds, and Pegasus .Not only do they have parts you might need that are not in kits. Also looking at the individual parts on their websites gives you an idea of what a new part looks, opposed to what may be a damage part.
R Weber DGV Advice Requested… TVR 19
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
B Weber DGV Spridgets 2
B Weber DGV Throttle Cable MG 2
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
bugedd weber DGV help Spridgets 6
sparkydave Weber DGV running at last! Spridgets 0
sparkydave Weber DGV and 1500 Spridgets 1
M Fuel pump rating for Weber DGV Carb? Spridgets 6
7 Weber 32/36 DGV with intake for sale or trade Triumph 1
7 Weber 32/36 DGV with intake for sale or trade Spridgets 0
X Weber 32/36 DGV fast idle rod MG 0
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv, selecting jets, air correctors? Spridgets 15
R weber 32/36 dgv parts? Spridgets 7
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
RickB Weber dgv for my Midget? Spridgets 14
R weber dgv 32/36 installation on 1500 midget? Spridgets 4
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
tosoutherncars WEBER DGV - what fuel pump / regulator do you use? Spridgets 8
C MGB Weber DGV setup on 74 MGB MG 13
eejay56 Weber DGV or twin SU HS4s Triumph 12
B Done with this Weber DGV Spridgets 3
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
B Weber DGV troubles... Spridgets 3
J Weber DGV on a Bugeye Spridgets 5
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
B Do Not give up on the DGV Weber..... MG 12
1976Midget weber DGV Spridgets 10
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
sparkydave Weber DGV for a 1500? Spridgets 10
S weber dgv tuning help Spridgets 3
A Vacuum Lines and Weber DGV's Triumph 3
M Flat Spot on my Weber 32/36 DGV MG 3
R Spitfire Sooty Spitty 79 W/Weber DGV Triumph 4
I WEBER DGV Carbs? Triumph 2
R weber DGV's Triumph 5
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
