Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32
kistinie
Hi,
I have already converted a DCD installed on a Davrian (Hillman Imp engine) without difficulties.I only oversized by 1,16 the jets keeping the rest intact.
To check the results i have an AFR meter with a wide band probe.
But getting a good transition is far more difficult than for idle and fast ride. The 1500 3000 band is difficult to balance in order to be stoichiometric at steady speed and accelerations, light and strong. I get a very weak mixture on light acceleration, a rich on strong.
On my Marcos GT Kent 1700, still on premium, same problem, i get 20/1 on light acceleration, 12/1 on steady opening and 14/1 on heavy acceleration.
I bet the emulsion tubes, idle and main are the problem.
As much as possible i want to avoid modification of the butterfly.
I currently have 130 main, 175 air on F16 and 45F8 for idle, Do you have suggestions or experience with other tubes on premium and ethanol.
Some suggest F9 on premium, F7 for E85, for idle F9 or F6 for E85
Thank you !
JHaydon
Weber recommends F2, F3, F4, F7, or F17 emulsion tubes for alcohol-based fuels.
They also recommend F7 to richen the mixture at low RPM and slight acceleration. F2 and F3 (and F16) will give a leaner low-end mixture under those conditions. Since you are going lean on light acceleration, I think the F7 is the tube you want.
If you don't already have a copy, hunt down How to Build and Power Tune Weber & Dellorto Carburettors by Des Hammill (Veloce Press, SpeedPro Series). That is the only book I've ever seen that gives good, solid starting points for jetting AND explains how to find the right idle jet F numbers (and explains how the idle jet F numbers actually work).
K
kistinie
I have just received F7, 55F6 for idle and 5 different main and air.145 to 185, 175 to 215
Next week with the AFR i start the test. I'm pretty certain to find a good combination with these. I also have a set of drill to do fine adjustments.
G Marcos GT Spotted 5
Boink 1973 Marcos MINI Spotted 1
Mickey Richaud Marcos, Anyone? Other British Cars 12
M 4CU EFI Module 3.5L Rover V8 1985 Marcos Mantula Rover / Land Rover 9
malice Anyone have a Marcos? or seen one in states? Other British Cars 20
Don Lattimer Marcos article - New York Times Other British Cars 1
MGA Steve Marcos Returns to U.S.? Other British Cars 5
Don Lattimer New Marcos to USA !! Other British Cars 14
78Z Interesting - Like New Mini Marcos British Motor Corp 9
Don Lattimer New Marcos TSO-GT2 Other British Cars 8
Don Lattimer 1970 Marcos on ebay Other British Cars 10
Bruce Bowker Marcos Other British Cars 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
