TR6 Weber Carbs and Redline Air Cleaners
Simmo
Is anyone running Triple DCOE 40mm Webers with Redine Air Filters? If so can you please tell me the model number you have. I dont want to spend the money if they dont fit.
Tybalt
Sorry for being late to the party but just fumbled and stumbled my way across this and saw no replies.
It would not shock me to find out the Redline air filters are made by K&N and if that is the case, then I have some information you should be able to use if you haven't already addressed everything. First off, due to how close the RH wheel well is to the mounted carburetors, the thickest air filter you can run is the 1 3/4" thick one. Next, you really need to run the velocity stacks since they not only smooth out air flow into the carburetor, they also hold the auxiliary venturi in place. Finally, the standard 40DCOE velocity stacks are too tall (26 or so mm IIRC) to fit properly in the 1 3/4" thick filter body and cover.
There are two problems to address when it comes to the stacks, where can you get 16mm velocity stacks for the 40DCOE. You can get them from Pierce Manifolds under what appears to be a genuine Weber part number 52840.006. The next issue is fitting them with the air filter base. I found that the lip where the hold down clips for velocity stacks go was larger than diameter than the hole in the K&N air filter base. I stuck an stack in the hole then ran a Sharpie around that outer diameter of the lip, then opened up the holes to the ink marks left by the Sharpie with a die grinder and double cut cylindrical burr. Hopefully if you get the filters from Redline, theirs will have that hole opened up already which would eliminate problem #2.
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
J TR2/3/3A weber carbs for TR3A Triumph 11
rikiwho123 weber carbs ? Triumph 0
Tim_Creger Need a book on Weber carbs MG 7
P MGA MGA and weber carbs.. MG 11
rjc157 weber carbs Triumph 7
L TR4/4A New weber carbs for my TR4 Triumph 10
10musketeer Weber Carbs Spridgets 3
KVH Dual Weber Carbs Triumph 4
T TR6 TR-6 vacuum connections for Weber MCHH carbs Triumph 2
L Big savings on Weber DCOE 45 carbs... Triumph 1
B weber side draft carbs British Motor Corp 15
philman Wedge weber carbs on tr7 Triumph 1
TR4 Converting from Stromberg to Weber Carbs? Triumph 23
I WEBER DGV Carbs? Triumph 2
R weber carbs Triumph 1
racing girl Weber Carbs Restoration & Tools 4
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
