TR4/4A TR3/TR4 Weber DCOE serious fitment issues
richie
Hi everyone,
I was excited a little while ago when I found and purchased a twin Weber DCOE 40 kit to replace my tired leaky Strombergs. The kit was purchased directly from Pierce Manifolds who took over design of TWM manifolds, and who is a massively large Weber distributor / tuner extraordinaire.
I got my car out of storage to find that the inlet manifolds were significantly interfering with the stock cast iron manifold. I first thought it was my header wrap, so I removed the wrapping, only to find it still wouldn't fit by a long shot due to clearance issues on the inside two cylinders. Here are a few examples of fitment issues with the inner runners:
So, my thinking is, I got Webers, maybe I need to buy a header as a sort of "price of admission". Turns out, very few people seem to be able to assure me their headers will be compatible with the oversized TWM inlet manifolds. I've tried BP Northwest, Rimmer Bros, TSI etc... And whats more surprising is that the manifolds don't even have enough clearance for the factory clamps which clamp on both the inlet/exhaust manifolds, the solution is to use hex/allen bolts with large washers which in my opinion wouldn't feel adequate:
I have only found one thread so far which indicated that the only inlet manifolds known to be compatible with the stock exhaust manifold is the CANNON manifolds. Fellow user Darrell_Walker posted a thread about his findings and seems to conclude that the TWM kit, as sold by Moss/Pierce, MAY fit with the Moss header.
At this point I am sharing this to share my experience with others, and hopefully, to find someone out there who might have some advice on how to successfully get these modern 'TWM' manifolds fitted on a TR3/TR4. I'm really having a hard time shelling another $500 for a header which will still have clearance issues with the Cyl #1 tubing.
Any wisdom or experience would be welcome, if not, maybe this thread will be a warning of the "fitment" of the TWM kits...
TR3driver
Great Pumpkin - R.I.P
I've no experience, but ISTR others saying they got them to fit with judicious grinding of all components involved (both manifolds and the clamps).
PeterK
What advice did Pierce have? Did you ask them since they sold you the manifolds? I'd always start there first.
M_Pied_Lourd
Not any help sorry, but just wanted to confirm as mentioned that the Cannon manifolds work with the Moss SS header. I did have to add a little weld to build up the contact area on the header where the football clamps held it but that's all the mods that were required.
Just a quick video of them installed...
https://youtu.be/_7QUGJqyCKw
Cheers
Tush
richie
richie
Pierce has been as helpful as they can be, their tech shop was telling me that they don't really sell very often to customers, more to shops/distributors like Moss etc, so they haven't had much first hand knowledge/experience of fitment issues. I've gotten the majority of my answers from Moss but we still can't seem to come to any solid conclusions.
At this point the more I think about it, there's no real solution besides buying another header and dealing with whatever final fitment issues there are with the header. I might need to seek reimbursement and go with Cannon's or go with another carb option.
richie
richie
Cheers
Tush
I've watched your videos a few times actually! Did you every try fitting them with the stock manifolds by any chance?
M_Pied_Lourd
Hi Richie,
No, I never did try with the stock exhaust manifold...sorry.
Cheers
Tush
richie
richie
Hey all, just wanted to log it for the history books. I ended up returning the kit as it looks like the only way this will work is if I order a header from Moss (they are not producing any at the moment due to their own fitment issues), or something else (TSI has a 4 week lead time and no confirmed fitment, BP Northwest has no confirmation of fitment either). Other option was to go with the Cannon linkage/manifold kit but that's just getting way too pricey. So unfortunately, no Webers for me in the near future. Contemplating SU's or Mikunis. Thanks to everyone for your insight.
scb10s
I have just finished installing a pair of Weber 40dcoe carburetors and TWM intake manifolds to my 67 TR4a. I did all my grinding on the intake manifold and clamps (football shaped ones) , no metal removed on the stock exhaust manifold. I was actually able to get the accelerator linkage, that was provided to work but, it wasn't all straight forward. I hooked my one man brake bleed vacuum pump up to the distributor so I could simulate manifold vacuum conditions; the PCV valve is not connected and this is where I'm looking for feedback from others. The new ( over ten years in the box) TWM manifold has no porting for PCV or distributor vacuum advance. I would like some coaching on what others have done to employee these two items into the overall engine system. The documentation on the Webers (40 DCOE 151) does not identify a vacuum tap for the distributor (still have the original one installed) and It has been converted to electronic ignition and I have no complaints with its performance. The engine runs very well as it should with nearly all new parts internally. Appreciate your feedback/guidance.
Stan
mctriumph
Just a side note, but the Jag 2 inch carbs will bolt-up to a Tr3 manifold netting you just as poor fuel economy
as the jag had.....I have seen weber conversions that got terrible fuel economy too .No doubt due to lack of tuning
on the DIY owner. Guess anything can be done wrong...
Mad dog
davidzeeso
Stan - 1960 TR-3A, installing as you did, file and grind on manifolds complete. ?How to insert black plastic sleeves for linkage rod?
Did you solve vacuum advance connection problem? I had anticipated reusing air filter arrangement I had on Weber down drafts,
but read that the air horns are essential for DCOEs. How did you fit air filter(s)?
David Z
Jim_Stevens
Short horns and ITG foam filters.
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
S TR2/3/3A Are a tr3 and tr4 radiators the same Triumph 3
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
M TR2/3/3A Is a Tr4 Work Shop Manual Useful for a TR3 owner? Triumph 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T TR2/3/3A TR4 Air cleaners on TR3 Triumph 7
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
K TR2/3/3A TR3 and TR4 Frame Width? Triumph 1
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
O TR2/3/3A TR4 overdrive in TR3 Triumph 4
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
O TR2/3/3A TR4 Wires to TR3 Triumph 11
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
K TR4/4A TR4/TR3 clutch operating shaft availability? Triumph 2
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
Tr3aguy TR4/4A Amp Gauge TR3 vs TR4 Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
6 TR4/4A TR3 [TR4?] Generator available??? Triumph 10
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
Marvin Gruber TR4/4A Windshield motors TR3 & TR4 Triumph 2
M TR4/4A TR3 TR4 exhaust hanger question Triumph 4
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
TR4nut TR4/4A Differenc e between TR3 and TR4 lever shocks? Triumph 6
S TR4/4A late tr3 and tr4 gas caps Triumph 4
HerronScott TR4/4A TR3/TR4 tool roll on eBay? Triumph 3
M TR4/4A New TR3-TR4 RingTolerance Questions ???? Triumph 7
mountainman TR4/4A TR3 - Tr4 Temp Gauge Triumph 5
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
T TR6 TR6 seats fit into a TR3 or TR4? Triumph 10
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
T TR4/4A Corbeau seats in TR3 or TR4 Triumph 12
T TR4/4A TR3 or TR4 piston replacement question Triumph 2
T TR4/4A TR3 vs TR4 Radiator Triumph 2
T TR4/4A TR3 / TR4 heater question Triumph 2
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
