TR2/3/3A TR4 Wires to TR3
oxendine
I've got a TR4 with wire wheels and would like them on my steel wheel TR3. The parts books seem to indicate the rear hubs will bolt to a TR3 but the fronts are a different part number. Will they work?
Thanks
TR3driver
Great Pumpkin - R.I.P
How old is your TR3? If it has front disc brakes, then the TR4 wheels are a direct bolt-on affair; just shorten the studs or use spacers under the adapters. I would NOT try to swap the rear hubs (which is a major task), although you could swap the front hubs if you want.
I believe you can also install the adapters onto the earlier "Lockheed" axle (cars with front drum brakes), but there may be some fitting involved. In that case though, the rear hubs will definitely not swap (although the fronts might).
Hmm, I looked it up; I don't understand your comment about the front hubs being a different part number, unless you are looking at the early (Lockheed) front hubs. After TS13046 (introduction of front disc brakes), the TR3 used 114283/114284 hubs (the only difference is the length of the studs), which are the same numbers shown in my TR4 parts book.
Donnie,
Unless you have the early TR3, it will be a easy bolt on swap. The 60 spokes will work fine. As Andy mentioned and I strongly agree, buy a set of spacers and use them under the adapters, that way you can change back to steel wheels or aftermarket wheels whenever you want. Easy to cut off but a pain to replace the long studs later.
Marv
Geo Hahn
I swap between discs & wires on my TR3A & TR4 -- using some 1/4" or 6mm spacers:
I got them locally at a hot rod shop though I think some of the usual vendors may also have them.
O
oxendine
I have a 1960 TR3 so the wheels should be a direct bolt on using the spacers? I'm assuming the rears will also work? As for the part numbers I was referring to a VB part number. I might have been looking at an earlier model.
Geo Hahn
I have a 1960 TR3 so the wheels should be a direct bolt on using the spacers?...
Yep, that's all there is to it. You will, of course, need to use the bevel nuts designed for the wire wheel hub.
Also -- if your spare is still a disc wheel (mine is) be sure to carry a set of regular lug nuts and the appropriate wrenches for both sets of nuts.
Joe Alexander sells ( on ebay) a solid alum plate that is machine out very nicely for the adapter spacer. I've bought a couple of sets. They are great.
Marv
M TR4/4A TR4 door glass spacer wires. Triumph 1
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 6
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
