TR4/4A TR3 - Tr4 Temp Gauge
mountainman
I know this might be a stupid questions., but I have to ask.
Can I use a tr4 temp gauge on my tr3 by using a temperature transmitter and voltage
stabilizer the way it is wired in a tr4???
TR4nut
yep!
And I don't think its a stupid question, since I was thinking the same thing before I finally found a capillary gauge. If you are very lucky, you can even find an early TR4 dome gauge that is electric, it will look just like the capillary version.
MGTF1250Dave
Aloha,
I concur that it can be done. You can even add the fuel gauge to the circuit with the voltage stabilizer.
My TR3A had an electric temperature gauge when I got it, unfortunately it did not have a voltage stabilizer. With out the a constant voltage to the gauge there are wild fluctuations of the indicated temperature. At highway speed when the generator is producing voltage above 12 volts you get a very high temperature reading. When you stop, and the engine is idling and the generator output voltage drops the gauge shows a very cool engine temp, well below normal operating temp. So, if the gauge acts like this you probably have a faulty voltage stabilizer.
With a convex gauge glass it will look at home in your TR3.
Geo Hahn
The TR4 gauges have a shroud which I think is removable. Glass can be easily switched from flat to dome if that is needed for a match.
Of course a few late TR3s actually used an electric gauge, with one of those it would be a spot-on match. Thay come up on eBay from time to time.
Mountainman -- do you have a defunct capillary tube gauge? If so and you a not going to use it I might be interested in it.
TR3driver
Great Pumpkin - R.I.P
Geo, I don't believe any TR3s ever came from the factory with electric temp gauges, even TR3Bs made after the start of TR4 production. Lots of eBay sellers advertise something other than what they actually have (one of them assured me that the disc rotors he was selling were the original size for my TR2!) But the early TR4 electric gauges do look VERY similar, and were a popular conversion even then.
Also worth noting that while the TR4 gauges certainly do need a stabilizer; there were gauges of similar (if not identical) appearance that did NOT need a stabilizer. These were 'balanced' movements, similar to the TR3 fuel gauge; and sold as aftermarket accessories for cars not originally equipped with temp gauges. I have one somewhere, still in it's original display carton.
Anyway, in response to the original question, Yes, it's very doable. The TR4 sender will screw right in where the TR3 sender was, no adapter needed. The stabilizer does need to be grounded, but the original type stabilizers do not care about polarity so you can keep positive ground if you want.
The aftermarket electronic ones do care about polarity though, so if you go electronic, be sure to get one that matches your setup.
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
S TR2/3/3A Are a tr3 and tr4 radiators the same Triumph 3
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
M TR2/3/3A Is a Tr4 Work Shop Manual Useful for a TR3 owner? Triumph 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T TR2/3/3A TR4 Air cleaners on TR3 Triumph 7
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
K TR2/3/3A TR3 and TR4 Frame Width? Triumph 1
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
O TR2/3/3A TR4 overdrive in TR3 Triumph 4
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
O TR2/3/3A TR4 Wires to TR3 Triumph 11
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
K TR4/4A TR4/TR3 clutch operating shaft availability? Triumph 2
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
Tr3aguy TR4/4A Amp Gauge TR3 vs TR4 Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
6 TR4/4A TR3 [TR4?] Generator available??? Triumph 10
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
Marvin Gruber TR4/4A Windshield motors TR3 & TR4 Triumph 2
M TR4/4A TR3 TR4 exhaust hanger question Triumph 4
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
TR4nut TR4/4A Differenc e between TR3 and TR4 lever shocks? Triumph 6
S TR4/4A late tr3 and tr4 gas caps Triumph 4
HerronScott TR4/4A TR3/TR4 tool roll on eBay? Triumph 3
M TR4/4A New TR3-TR4 RingTolerance Questions ???? Triumph 7
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
T TR6 TR6 seats fit into a TR3 or TR4? Triumph 10
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
T TR4/4A Corbeau seats in TR3 or TR4 Triumph 12
T TR4/4A TR3 or TR4 piston replacement question Triumph 2
T TR4/4A TR3 vs TR4 Radiator Triumph 2
T TR4/4A TR3 / TR4 heater question Triumph 2
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
