TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection
GerryL
What recommendations would you recommend for a stock TR4 engine with 87 cylinder liners? I have heard that the head gaskets for the standard bore 86 cylinders will result with the gasket extending into the combustion chamber, resulting in shorter head gasket life. There also seems to be significant variation in prices for the copper clad gaskets. Does higher price correspond to better quality. BPNW has a cylinder gasket (Head Gasket Set Big Bore 87mm to 90mm) which is described as providing a better seal without extending into combustion chamber. This gasket is described as "made with a perforated steel core and and elastomer surface that heats very evenly for a superior seal, plus the fire rings are made from a stainless steel. No blown head gasket with this head gasket". Would this 87/89 gasket provide any real benefit to justify the significant price difference?
TR3driver
Great Pumpkin - R.I.P
Rumor has it that Payen has stopped production of those. But the last "no name" 86mm composite gasket I got from TRF had plenty of clearance for use with 87mm liners. I expect it will work fine.
However, double-check that the liner protrusion is within spec (.003" to .0055") when you measure on either side. I fought with head gasket issues for many years until I realized that I was always measuring on the same side ... when measured on the other side there was no protrusion at all! I've now found this on two engines in a row, so I have to think it is somewhat common. (But both were fairly early TR3 engines, so maybe it's not as common on later engines.)
Although the "right" solution would be to have the block machined, I worked around the problem by adding a ring of copper wire around each cylinder, soldered to the head gasket (mostly just to hold it in place during assembly). I covered over 100,000 miles on the engine I had in my (now wrecked) TR3A and never had a head gasket problem again. When the current TR3 started leaking after just a few months, I found the same problem (to a lesser extent) and applied the same fix. It's still going some 5 years later.
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
S TR2/3/3A Are a tr3 and tr4 radiators the same Triumph 3
M TR2/3/3A Is a Tr4 Work Shop Manual Useful for a TR3 owner? Triumph 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T TR2/3/3A TR4 Air cleaners on TR3 Triumph 7
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
K TR2/3/3A TR3 and TR4 Frame Width? Triumph 1
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
O TR2/3/3A TR4 overdrive in TR3 Triumph 4
O TR2/3/3A TR4 Wires to TR3 Triumph 11
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
K TR4/4A TR4/TR3 clutch operating shaft availability? Triumph 2
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
Tr3aguy TR4/4A Amp Gauge TR3 vs TR4 Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
6 TR4/4A TR3 [TR4?] Generator available??? Triumph 10
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
Marvin Gruber TR4/4A Windshield motors TR3 & TR4 Triumph 2
M TR4/4A TR3 TR4 exhaust hanger question Triumph 4
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
TR4nut TR4/4A Differenc e between TR3 and TR4 lever shocks? Triumph 6
S TR4/4A late tr3 and tr4 gas caps Triumph 4
HerronScott TR4/4A TR3/TR4 tool roll on eBay? Triumph 3
M TR4/4A New TR3-TR4 RingTolerance Questions ???? Triumph 7
mountainman TR4/4A TR3 - Tr4 Temp Gauge Triumph 5
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
T TR6 TR6 seats fit into a TR3 or TR4? Triumph 10
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
T TR4/4A Corbeau seats in TR3 or TR4 Triumph 12
T TR4/4A TR3 or TR4 piston replacement question Triumph 2
T TR4/4A TR3 vs TR4 Radiator Triumph 2
T TR4/4A TR3 / TR4 heater question Triumph 2
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
