For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420
Status
Not open for further replies.
groupdeville
[h=2]NOT a re-grind, the Real Thing on Kastner-stamped blank[/h]Original Kas Kastner "D" Grind 4-Cyl "TR" Engine Camshaft with Very Few Miles and in Excellent Condition, with Kastner end-stamp.
(NOT a re-grind - this is the Real Thing on a Kastner-stamped original Triumph Blank)
If you're reading this listing, you probably already know all about who Kas Kastner is: The leading light in Triumph high performance and racing development in the USA..for close to 60 years. Many of the racing modifications and high performance tricks that are everyday practice in the Triumph world began with this one man and his scientific approach to development of the cars for increased performance. Author of several books, the Triumph Competition Preparation Manuals, as well as being a mentor to all in the Triumph performance world, and a nice guy too!
"Back in the Day" Mr. Kastner developed and sold (through Triumph dealers in the USA) a series of high performance and racing camshafts for the 4-cylinder Triumph "TR" and Morgan +4 engine. The Kastner cams were ground on full-size blanks straight from Triumph. The first one (I think) was "C", then "D" and on through to the "F" and "G" cams. Of these, the "C" is fairly mild by today's standards, while the ones beyond "D" are considered race or sprint only, rather than street-driveable cams for normal folks.
That leaves the "D" cam, as listed here. Its reputation is that it's about the highest-performance Kastner cam that's still good for street use. The description and specs of the D-grind (from Mr. Kastner's own book) are:
The "D" camshaft is now suggested for street/race use, but there must be an increase in the compression ratio. The minimum compression ratio is 10:1. Without this increase in compression, the r.p.m. range below 3500 will be very sluggish. The (ed. note: peak) power range on the "D" camshaft is between 3500 and 5500 r.p.m. The timing of the "D" camshaft is as follows:
Inlet opens 33 degrees BTDC
Inlet Closes 71 degrees ABDC
Exhaust Opens 71 degrees BBDC
Exhaust closes 33 degrees ATDC
Duration is 284 degrees
Total lift at the valve is 0.393"
When using a degree wheel, the checking clearance is .010" at the camshaft
The rocker arm adjustment is .014" hot
History: Briefly, I purchased this camshaft a few years ago (OK, it was about 35...) from a man at the British/Import Swap Meet that used to be held in the Rio Hondo College parking lot in Los Angeles. Bought it together with a Judson supercharger kit. The fellow I bought the two items from said that his brother had had both items in his TR4 engine, and quickly discovered that he didn't like the way it ran - so he removed the parts and started on a 289 Ford V-8 engine transplant. Obviously, a semi-long duration cam like the Kastner D would always be a really poor match for a supercharger kit (lots of "blow-through"), which accounted for the engine not running strongly. I have no idea what compression he was running.
The very short run-time accounts for the excellent condition of this camshaft, and as you can see from the photos, the "blacking" of the surfaces (done when a cam is reground) is still intact in most wear areas. Photos also show the "Kastner D" markings and the part numbers of the original Triumph factory blank upon which the cam was ground.
I've had this cam in dry indoor storage since it was purchased, it's moved across the country with me twice, and I haven't gotten around to putting it into an engine yet - so hopefully you will find good use for it out on the road in your Triumph, Morgan, Doretti, Italia, Peerless, or Bitsa.
$420, with FREE USA SHIPPING and NO Sales Tax !
I can send you photos that I've taken of the cam (please provide email address in your PM), or the listing will be visible on ebay this evening (22 September 2017) sometime after 6:00 PM.
Thanks for your interest!
G
groupdeville
Re: Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig.
Please close this thread - Camshaft was sold on ebay.
Status
S TR2/3/3A WTB a tr2 original grill Triumph 0
S Wanted tr2 original grill Triumph Classifieds 10
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
P General TR What color is original for engine parts? Triumph 7
EWD For Sale ā€˜74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ā€˜74 TR6 original radio Triumph Classifieds 0
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
PAUL161 T-Series Original transmission sold MG 2
T For Sale TR3A Original Radiator Triumph Classifieds 3
N MGB Not original to my 70 MGB? MG 18
C For Sale BJ8 original dash Austin Healey Classifieds 3
PAUL161 T-Series Original 1955 MGTF Photos MG 6
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
LAW75 Concours: Original Gas Hose Austin Healey 12
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
Rob Glasgow Found Original Owner Austin Healey 2
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
S TR2/3/3A restore my original air filters Triumph 5
T Original Door Pocket Spridgets 14
G Original clamps for Petrolex hose Austin Healey 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
NutmegCT For Sale My 1953 MG-TD - Original, one owner 1953 to 2017 MG Classifieds 13
I TR6 Thickness of original TR6 dash Triumph 2
DerekJ Original steering wheels Austin Healey 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
Z For Sale 1955 MG TD Original car, numbers matching, restored to immaculate condition MG Classifieds 10
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
G For Sale Morgan Folding Windshield Posts, Original 1960s-70s ā€œSmall Quadrantā€ Style, $600 Other British Classifieds 0
Cutrog1 How do I respond to all responses and add progress report on original article? FORUM Navigation Questions 3
F Which Original Oil filter assembly for BN7 Austin Healey 19
B TR4/4A Original gearbox bearings Triumph 14
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
H TR2/3/3A Original Dunlop 5.50X15 Bias Ply Tire Data Triumph 4
