WEBER DGV Carbs?
Izual Angel
I'm referring to the kit for TR7s. Is this a good kit? I'm not looking for Hi performance but just something more reliable. There's a set of them on ebay now, just wondering if it's a complete waste of money.
Mark Beiser
There is bound to be some debate on it, but IMO, the stock ZS carbs are superior to the webber carbs for normal street driving. Converting over to fixed venturi webber carbs will probably increase your fuel milage and top end power slightly on a stock engine, but you will loose some low end torque.
If your really having problems with keeping your carbs in tune, it may be time for a major overhaul on them, new shafts, needles, main jets, shaft bushings, return springs, etc., not just a kit.
Be sure there are no other issues going on with the engine that may be acting like a carburetor problem also.
Properly set up ZS carbs in good condition are really not nearly as unreliable as thier reputation, besides, ALL of the downdraft webber conversions for the TR7 just look ugly under the hood. /ubbthreads/images/graemlins/wink.gif
MrBlueSky
/ubbthreads/images/graemlins/iagree.gif Yes, properly tuned ZS are quite reliable and can give you good everyday performance. I rebuild mine and then take the car to my mechanic to do the tuning. Im lucky to have a factory trained BL mechanic that lives about 20mi from me.
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
B Weber DGV Spridgets 2
B Weber DGV Throttle Cable MG 2
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
bugedd weber DGV help Spridgets 6
sparkydave Weber DGV running at last! Spridgets 0
sparkydave Weber DGV and 1500 Spridgets 1
M Fuel pump rating for Weber DGV Carb? Spridgets 6
7 Weber 32/36 DGV with intake for sale or trade Triumph 1
7 Weber 32/36 DGV with intake for sale or trade Spridgets 0
X Weber 32/36 DGV fast idle rod MG 0
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv, selecting jets, air correctors? Spridgets 15
R weber 32/36 dgv parts? Spridgets 7
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
RickB Weber dgv for my Midget? Spridgets 14
R weber dgv 32/36 installation on 1500 midget? Spridgets 4
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
tosoutherncars WEBER DGV - what fuel pump / regulator do you use? Spridgets 8
C MGB Weber DGV setup on 74 MGB MG 13
eejay56 Weber DGV or twin SU HS4s Triumph 12
B Done with this Weber DGV Spridgets 3
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
B Weber DGV troubles... Spridgets 3
J Weber DGV on a Bugeye Spridgets 5
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
B Do Not give up on the DGV Weber..... MG 12
1976Midget weber DGV Spridgets 10
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
sparkydave Weber DGV for a 1500? Spridgets 10
S weber dgv tuning help Spridgets 3
A Vacuum Lines and Weber DGV's Triumph 3
M Flat Spot on my Weber 32/36 DGV MG 3
R Spitfire Sooty Spitty 79 W/Weber DGV Triumph 4
R weber DGV's Triumph 5
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
