weber DGV help
bugedd
Another issue with my motor upon putting it back in the car is the Weber DGV seeping fuel. When I pulled things apart about two months ago, I pulled the intake assembly off as one unit and set it aside. The only thing I did to it was changing the fuel feed. Looking at the fuel inlet on mine, there is one nipple that feeds at a 45* angle into the bottom, and its pointed at the motor. Well I didn't like that so a local street rod guy suggested capping that off and drilling/tapping the large bottom plug and putting a nipple in there. Made for a nicer fuel line feed, but does the changing of the fuel inlet cause the carb to overfill or something? It seems like I heard an awful lot of noise when the electric fuel pump was filling up the bowl, more than I have ever heard.
Platinum
Could you have gotten some drilling swarf introduced to the needle/seat?
bugedd
bugedd
No, the plug was pulled when drilled/tapped. Everything should be clean.
Deleted member 8987
"should be clean" doesn't count.
Leaking or overfilling?
Take a piece of torn paper, wipe the bottom of the threads of your new fuel inlet after making sure you have fuel pressure), and look. If it's wet at ALL, it's leaking.
Sealant works well in that location, just don't get any into the fuel part.
Taps do a good job of threading holes, but not necessarily nice enough to seal fuel.
You need to be VERY careful, good or new tap, and lots of oil, or you get roughness in the threads that won't allow proper sealing.
Is it leaking at the top cover gasket?
Usually if overfilling, you will see fuel dribbling down the throat first.
Electric pump?
Turn it on, air cleaner off, prop the choke open, and look with a sealed electric flashlight (just in case you were thinking of using your Zippo).
If it's not dribbling, probably not a high fuel level.
When they leak from high fuel level, the fuel drops to the butterfly/shaft, pools, and runs out the shaft ends.
bugedd
bugedd
Electric fuel pump, and I noticed the base gasket was wet, and it dripped down from there on the car. I'll pop off the air filter tomorrow and run the pump and try to see anything in the carb and post what I find.
60bug
Member
Hi, please let me know as I'm considering making the same change to my DGV carb, I dont like the way the fuel line is routed so close to the engine out of the carb. Did you end up picking up the new bugeye body in Arnold?
bugedd
bugedd
No, the one in Arnold, supposedly "99% rust free" and straight, was a roach. I put my hand through the inner rear fenders as well as the trunk pan. And every panel was roached. I did end up getting a roller out of Mariposa, still haven't seen it in person yet. A friend who has a resto shop was my eyes on that transaction for me. Can't wait to get down to Lockeford to check it out.
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
S weber dgv tuning help Spridgets 3
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
B Weber DGV Spridgets 2
B Weber DGV Throttle Cable MG 2
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
sparkydave Weber DGV running at last! Spridgets 0
sparkydave Weber DGV and 1500 Spridgets 1
M Fuel pump rating for Weber DGV Carb? Spridgets 6
7 Weber 32/36 DGV with intake for sale or trade Triumph 1
7 Weber 32/36 DGV with intake for sale or trade Spridgets 0
X Weber 32/36 DGV fast idle rod MG 0
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv, selecting jets, air correctors? Spridgets 15
R weber 32/36 dgv parts? Spridgets 7
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
RickB Weber dgv for my Midget? Spridgets 14
R weber dgv 32/36 installation on 1500 midget? Spridgets 4
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
tosoutherncars WEBER DGV - what fuel pump / regulator do you use? Spridgets 8
C MGB Weber DGV setup on 74 MGB MG 13
eejay56 Weber DGV or twin SU HS4s Triumph 12
B Done with this Weber DGV Spridgets 3
B Weber DGV troubles... Spridgets 3
J Weber DGV on a Bugeye Spridgets 5
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
B Do Not give up on the DGV Weber..... MG 12
1976Midget weber DGV Spridgets 10
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
sparkydave Weber DGV for a 1500? Spridgets 10
A Vacuum Lines and Weber DGV's Triumph 3
M Flat Spot on my Weber 32/36 DGV MG 3
R Spitfire Sooty Spitty 79 W/Weber DGV Triumph 4
I WEBER DGV Carbs? Triumph 2
R weber DGV's Triumph 5
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
