What fuel pressure does a Weber DGV like?
bthompson
After being stranded in traffic --twice-- this week, I tracked down the problem to my Facet-esque rattlecube fuel pump, which is deciding not to move any fuel at random intervals. Still rattling, just not pumping any volume.
So, time to replace it....but what with? I don't want to overwhelm my DGV, but then I realized I don't know what would overwhelm a DGV.
Anyone know off the top of their head what fuel volume and pressure works best for a Weber?
I know there's other stuff I should really track down first: a blocked line, plugged filter, stuck float, etc...just planning ahead for the worst.
Pythias
I have a Weber DGV installed. I happened to have a Holley Fuel Pressure Regulator on the car from when I had SUs. I didn't change its settings at all, so as is stated above, 2-3 psi works perfectly.
BobHaskell SU Fuel Pump Pressure Austin Healey 1
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
aero3113 Fuel pressure Austin Healey 36
B Fuel Pressure Regulator Spridgets 5
KVH General TR Fuel Pump Pressure Triumph 16
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
M TR4/4A Fuel Pressure Regulator Installation. Triumph 3
N Fuel pressure regulator? Spridgets 10
A 100/4 Fuel pressure advice needed Austin Healey 1
M How Do I check Fuel Pressure at Injector Rail 99 XJ8? Jaguar 5
S Fuel pressure Regulator is it really needed? Triumph 9
Henson80MGB Newbie w/ low fuel pressure issue MG 11
TR4 TR4/4A TR4 Fuel Pressure Triumph 20
mrsprite fuel pressure question Spridgets 6
T Fuel pressure regulator settings???? MG 7
T Recommended fuel pressure Spridgets 32
M 1987 XJ-6 Fuel Pressure Jaguar 9
P T-Series MGTD Fuel Pump Pressure MG 2
healeyboz fuel pressure question Spridgets 6
R correct fuel pressure Austin Healey 4
6 What Fuel Pressure? Spridgets 7
Bob Claffie Too much fuel pressure Austin Healey 9
Morris Midget EFI fuel pressure problem Spridgets 10
P fuel pressure problem MG 2
T Fuel pressure regulators Spridgets 25
H Fuel pressure regulator question MG 2
kennypinkerton Fuel pressure test gauge? Alfa Spider... Other Cars 2
G fuel pressure Spridgets 4
T fuel pressure, roll bar Spridgets 15
P ideal fuel pressure for webber or dellorto carbs Triumph 11
Hegg Excessive Fuel Pressure - how do I stop the leak? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
