1987 XJ-6 Fuel Pressure
Michael J.
I was having trouble with the car making low power, low RPM and backfiring. Car would idle fine.
I put a fuel pressure guage in the fuel line at the rear of the fuel rail.
30 psi at idle but only 15-20 psi at 2000 RPM. I changed the fuel pump. I now get 30 psi at 850 rpm idle, 30 psi at 1000 rpm, 30 psi at 2000 rpm and 28 psi at 3000 rpm.
I am trying to find out what the correct system pressure is.
Anyone know what pressure the regulator is supposed to be set at?
LarryK
28.5in/lbs to 30.8 in/lbs. to check the regulator clamp line form reg to tank, pressure will increase dramatically. Check your filter and non-return valves.
Low rpm backfire? Thru intake or exhaust?
M
Michael J.
I think the backfiring was in the intake and some in the exhaust as well. Fuel pump made a considerable improvement.
I will check out the weblink and try the pressure test by clamping the line from the regulator at the front of the fuel rail, which should be return.
M
Michael J.
Still having the problem, but only when I make a 90 degree turn either left or right, then RPM drops off to idle and is slow to come back. Car does not do this when going through curves, only when making a full turn from a stop such as at a stop sign or traffic light. In thinking back about the symptoms, that was how it behaved before swapping out the fuel pump.
Fuel pressure remains nearly consistant but does drop off to as low as 25 psi. I put a small c-clamp on the return hose at the front of the fuel rail where it connects the fuel pressure regulator with the return line rigid tubing. This boosted the pressure to about 35 psi. problem remained and the lowest pressure observed was about 32 psi when whatever is happening was happening.
I have a new fuel filter installed.
I have swapped the airflow meter earlier in this problem and I had some kind of bind in the throttle body in which the gas pedal was extremely hard to press. I lubed the throttle shaft on both ends and the bind went away. I replaced the throttle switch/potentiometer which is nothing but a switch inside the housing on US cars.
The pump had to be some of the trouble because the fuel pressure was dropping off,and then comming back to around 30 psi before I changed the pump.
This has me baffled.
Deleted member 8987
Maybe.
On constant-flow duel injection systems, the fuel continuously runs from the tank, pump, fuel rail, and back to the tank.
If you have a baffle issue in the tank, and the fuel runs to one side on a curve, you starve the system.
These tanks are fairly narrow, so there may not be a baffle.
How much fuel is in the tank?
Does the level of fuel make a difference?
The suction line in the tank may not be anywhere close to where it should be. Looks like it is in the sender unit.
Before you fill the tank for further testing, drain the tank, remove the sender unit and check the inlet pipe.
Deleted member 8987
I see some listings for XJ-6 with twin tanks, some with in-tank pumps.
And, I see a Fuel Sump on some models, with an in-tank filter.
Fuel Sump Tank C41794, filter JA-CBC5649.
JA-CAC5516-1 RH JA-CAC5517-1 LH with in-tank pumps.
C40190 RH and C40191 LH with external pumps, to VIN 2T 58223.
JA-CAC5522-1 RH, JA-CAC5523-1 LH, VIN 2T 58224 onwards.
A tad confusing.
You have one or two tanks?
You have a fuel sump?
Internal or external pumps?
M
Michael J.
The 87 XJ6 has an external fuel pump (same as my 90 XJS), in this case, each fuel tanl has a low fuel line that runs along the floor of the trunk to the rear of the spare tire and each line connects to the electric fuel change over valve. From the valve, a fuel line about 12" long runs to the inlet for the fuel pump. From there the fuelruns to the front of the car.
I will check the sender to see what is going on with the pick-up. I have one tank empty at present.
Power steering pump was empty. Car has been sitting a while while I have been fighting with this problem. Off to the store to get some Type F fluid for the pump. I'll comment about the effect it has.
M
Michael J.
Well...Problem still not solved yet. Power steering reservoir no longer low.
I have about a 1/2 tank fuel in the left tank, which is the tank I have been running on. I'll add some fuel to the left tank, or maybe fill the right tank to see if tank selection factors in.
I plan to start by pulling the right tank sender, since the tank is empty to check the fuel pick up.
I did notice that when it is making low rpm and low power, iff you pump the throttle you can work up the rpm gradually. Does this sound like an Air Meter problem?
There is no fuel sump tank. My V-12 XJS has one, so I wonder if the XJ12 version has the sump mentioned by TOC?
Sherlock For Sale FS: 1987 Reliant Scimitar 1800Ti Other British Classifieds 0
J 1987 xj6 questions. Jaguar 10
TR6oldtimer 1986/1987 TRF parts book Triumph 4
wkilleffer 1987 Nissan Maxima Other Cars 6
T TR2/3/3A fuel pump oil leak Triumph 5
M MGB Fuel pump Banjo fittings MG 1
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 10
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
