Fuel pressure Regulator is it really needed?
ScottFromNH
Hi Everyone.
I have a 1973 Spitfire 1500 running a single Stromberg carb and was told I should install a fuel pressure regulator and trying to find out if this is good advice or if its not needed? Not sure what the point would be?
any thoughts.
scott
TR3driver
Great Pumpkin - R.I.P
The main reason for installing a pressure regulator would be if you have a fuel pump that is putting out too much pressure.
That is also the only time I would consider adding one. The regulator can only work with some certain minimum pressure drop across it, so it cannot deliver the 2.5 - 4 psi that your carb wants if it is only getting 2.5 - 4 psi from the pump.
The racers like to use high capacity pumps and a pressure regulator, so they can be certain of getting enough fuel when operating at higher power (and hence higher fuel flow) than the system was designed for. Good idea for a race car, pointless for an otherwise stock setup IMO.
S
ScottFromNH
Thanks TR3Driver. Yeah not a racer just will be a regular road car and I just installed a new fuel pump so I should be good then :smile:
TR3driver
Well, it's not unheard-of for new pumps to (incorrectly) put out too much pressure. Are you getting any bad symptoms, like fuel running out of the carb, or black smoke from the exhaust?
S
ScottFromNH
oh didnt know that. No actually the engine seems to run really nice especially since the carb hasnt been rebuilt yet and it sat for 10 years. Now fuel leaking out. It idles at about 900 rpm when the chock is fully in and sounds good. I was just told by an old guy that I should put it in to help prevent problems down the road.
S
ScottFromNH
Thanks Tomshobby its funny you send that link before I posted this I was actually looking at that one. I only have one carb and after posting this I dont think I need one
70herald
ScottFromNH said:
and was told I should install a (fill in the blank)
any thoughts.
scott
Well my $0.02.... About 1/2 of what you will be told has almost no basis in fact.... the other 1/2 is probably wrong.
English carbs use a much lower fuel pressure than american designs (in general) so after people much up the original design by substituting a pump designed for american carbs, the carb will flood since the valve can't handle the higher pressure. Then they invent stories about needing a pressure regulator since they mucked up the original design.
As long as your stock fuel pump has a diaphragm which can handle modern fuel, you are all ready to go. The only thing I would consider adding is ONE fuel filter, the simple type designed for carbs.
S
ScottFromNH
Thanks 70herald,
I will stick with that is then already then instead of causing more issues for myself.
I actually have 2 inline fuel filters that are designed for carbs installed. One at the gas tank and then I have one between the fuel pump and carb. When I got the car it actually had 3 of them (one at the tank, one before the fuel pump, one before the carb) after talking to guys on this forum I removed the one right before the fuel pump since I had one right when the line was leaving the tank and I installed all new lines when I sealed the tank and replaced the fuel pump.
B Fuel Pressure Regulator Spridgets 5
M TR4/4A Fuel Pressure Regulator Installation. Triumph 3
N Fuel pressure regulator? Spridgets 10
T Fuel pressure regulator settings???? MG 7
H Fuel pressure regulator question MG 2
BobHaskell SU Fuel Pump Pressure Austin Healey 1
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
aero3113 Fuel pressure Austin Healey 36
KVH General TR Fuel Pump Pressure Triumph 16
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
A 100/4 Fuel pressure advice needed Austin Healey 1
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
M How Do I check Fuel Pressure at Injector Rail 99 XJ8? Jaguar 5
Henson80MGB Newbie w/ low fuel pressure issue MG 11
TR4 TR4/4A TR4 Fuel Pressure Triumph 20
mrsprite fuel pressure question Spridgets 6
T Recommended fuel pressure Spridgets 32
M 1987 XJ-6 Fuel Pressure Jaguar 9
P T-Series MGTD Fuel Pump Pressure MG 2
healeyboz fuel pressure question Spridgets 6
R correct fuel pressure Austin Healey 4
6 What Fuel Pressure? Spridgets 7
Bob Claffie Too much fuel pressure Austin Healey 9
Morris Midget EFI fuel pressure problem Spridgets 10
P fuel pressure problem MG 2
T Fuel pressure regulators Spridgets 25
kennypinkerton Fuel pressure test gauge? Alfa Spider... Other Cars 2
G fuel pressure Spridgets 4
T fuel pressure, roll bar Spridgets 15
P ideal fuel pressure for webber or dellorto carbs Triumph 11
Hegg Excessive Fuel Pressure - how do I stop the leak? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
