T-Series MGTD Fuel Pump Pressure
PlaidMan
Would anyone happen to know what the fuel pump pressure is for a 1952 MGTD? I'm considering installing an aftermarket type fuel pump and I know it should be a low pressure pump and hopefully I could purchase it at one of the local parts stores. Thanks, Charlie
Platinum
2.5~4 PSI. The metal "cube" Facet pumps should work. NAPA, etc. Carter has an in-line "lift pump" meant to be submersible I've used with success too. Part number P60504. Low pressure.
R T-Series Valve gap for an MGTD 1953. MG 5
B T-Series Battery replacement mgtd MG 2
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
PAUL161 T-Series Custom MGTD MG 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
A T-Series MGTD oil pump bypass valve MG 0
A T-Series Mgtd oil pump alterations MG 2
P T-Series Lea-Francis MGTD MG 10
P T-Series MGTD - before and after MG 3
H T-Series MGTD Christmas Ornament MG 1
vickxxx T-Series 1952 MGTD spark plugs. MG 4
bfitz T-Series 1951 MGTD oil pressure question MG 5
vickxxx T-Series turn signals for MGTD MG 5
smaceng T-Series Does a 1952 MGTD use a 12V battery? MG 4
richberman T-Series MGTD suicide door lock lever orders MG 0
B T-Series MGTD brake shoes. Are there leading and trailing shoes? MG 1
F T-Series MGTD Factory Original Color MG 5
justin_mercier T-Series Dimensions of an MGTD windscreen? MG 1
S T-Series MGTD SEAT MG 1
rick_ingram T-Series Wanted To Find - MGTD #1091 MG 6
mountainman T-Series MGTD Top Insutlation MG 4
T MGTD -- Columbus Spotted 0
M T-Series soft plug 52 mgtd MG 3
mountainman T-Series MGTD What is it worth MG 2
G T-Series MGTD Steel wheels MG 3
B T-Series Pic of my MGTD MG 8
C T-Series Need a MGTD Steering Wheel MG 5
G T-Series Newbie '51 MGTD MG 2
Steve P. T-Series Which Volvo engine fits in an MGTD? MG 40
Hedgehog T-Series MGTD sighting MG 3
P T-Series MGTD Front Brake Drum Removal? MG 9
CCURTISS T-Series MGTD/TF Carbon Release Bearing Question MG 3
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
J T-Series MGtd looking at one Sunday-need some help MG 4
T T-Series MGTD Supercharger MG 2
rick_ingram T-Series MGTD Crankshaft MG 6
6 T-Series MGTC / MGTD Period Correct Carb/Intake Systems MG 8
Steve P. T-Series any MGTD's with custom bodies out there? MG 7
W T-Series MGTD rear oil seal leak MG 7
G T-Series Dropping the oil pan on my MGTD MG 1
beaulieu T-Series MGTD engine/gearbox same as other MGs? MG 21
beachbumbarry T-Series MGTD anti-sway bar MG 4
EinsteinsDad T-Series MGTD Front suspension and Swivel / King pins MG 4
beachbumbarry T-Series MGTD basket case MG 16
T T-Series smiths or arnolt heater installation in an MGTD MG 1
martyc T-Series My MGTD-related Web Log MG 5
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
