T-Series Valve gap for an MGTD 1953.
R
Russ V
I have a 1953 MGTD that I have owned for 45 years. A few years ago I rebuilt the engine (with help from someone more knowledgeable) and had a problem with the head. It had a large crack in it forcing me to install a different head. The original head was for a newer MGTD with circular holes for antifreeze cooling. I was unable to find an identical head and the mechanic told me that an older head would work fine with the "banana-shaped" holes for cooling. Luckily I found a head on E-Bay and had it checked out by a shop that specializes in heads. The problem I am now facing is not knowing what "GAP" (lash) I need to set the valves. Should I set the valves at .012" or .019" ??????? .019" is for the older (banana hole) head up to engine 24115 and .012" is for the newer (circular hole) head after engine 24115. I obviously can't go by my engine number since the head is for an older engine.
Any suggestions are appreciated. I temporarily set them for .015" as a compromise.
PAUL161
.015 is fine! The valve train will be fairly quiet and no chance of burning a valve. PJ
R
Russ V
Thanks for the update. Makes me more confident. They are a little noisy but better to be a little loose than too tight. My biggest concern was that "IF" they should be .019" and I set them .015" they might be tighter than they should and damage the valves. Drive Safe!
PAUL161
If you only drive around town or secondary roads at normal speeds, .012 shouldn't do any harm and they would be quieter. I have a Crane cam in my TF and Crane calls for .018 to .019. PJ
R
Russ V
Thanks for your reply. I only drive around town and never go above 3500 RPM.
I also spoke to Tech support at Moss and he felt that .012" to .015" is perfect. (.012" being a little tighter than .015" but may add a little power)
He did mention (and I agree) that a little loose is better than tight.
He also mentioned that originally they MG recommended .019" but modified it to .012" after a few years to resolve some complaints about noisy lifters. (I don't mind noisy lifters..... the rest of my "noises" drowned out the lifters.... lol)
I have to check the gap again - I've lost a LITTLE power and possibly have a little wear going on for the tappets, valves, or push rods. Either I have to re-adjust or will try .012". That may bring back a little of the lost power. I also have to re-torque the head.
Thanks for everyone's reply. FORUMS ARE GREAT!!!!!!
JPSmit
I might add that an Italian tuneup might be helpful after you have established the gaps. No more than 3500 and in town makes for a sad MG.
and yes, forums are great!!!
K TR2/3/3A Street cam again and Valve gap? Triumph 6
K Paging Martx-5...What valve gap are you using? Triumph 0
K TR2/3/3A TR3...Mild street cam....valve gap? Triumph 8
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
H BJ8 Heater Valve/Control Tap Austin Healey 3
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
G Valve adjustment and easiest way set cam position Austin Healey 15
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
dbenichou289 TR2/3/3A Valve seats Triumph 8
steveg TR6 Adding a PCV valve Triumph 5
