TR2/3/3A Valve seats
dbenichou289
Member
So I just received some valve seats from a TR3 supplier as I am rebuilding the cyl head, but received 3 different sizes: 20-1437-3 (1.43" OD), PC-1500-29 (1.5" OD), and PC-1625-36 (1.625" OD). Can anyone confirm/deny which size valve seats are required, for both intake and exhaust?
Madflyer
Ex would be smaller and fit would be about .003 tight. how many seats did you get 4 of each 8 of each??? Madflyer
dbenichou289
dbenichou289
Member
I received one of the 1.43", 3 of the 1.5" and 4 of the 1.625. So at this point I am not sure which is correct.
Madflyer
Did you get valves also and the correct stem size if so seats fit valves not yet ground. If you have removed old seats the new ones will need to be ground to fit hole in head. apox .003 plus each pocket in head may be different plus or min. The four the same would be intake and the four cut to fit to say . Note they are just harden steel ring and after setting into head and ground to valves ( three step ) they become as we would call them valves seats. I looked around the web and found little info. as to parts locations. Did you look at You Tube?? I went to a class on setting seats on a Jag head each seat was ground to head hole non were the same. Now Jag heads are alum. and the head was heated to 500 deg. F Madflyer
dbenichou289
dbenichou289
Member
I have not removed the old ones yet. I would prefer to begin with having a complete set of matching rings. The valves are in great shape so I was looking at reusing. I am replacing the valve guides to the bronze ones.
CJD
The standard valve heads are 1.56" intake and 1.30" exhaust. I assume you are having the seats installed by a shop, so I would recommend you let the shop handle the decision. I assume the 1.43's and 1.5's would work for the exhaust, but the 1.6's may be getting on the large side to risk cutting into the intake valve seat. Seats are not hard to get in any size, so I let my machine shop buy and install them. Guides are the same...nothing special in our guides, so any shop can buy and replace those too.
Madflyer
I did some checking around and the best I got was a name and number so call this parts guy. Steve Old farts ( may be PH not F )British parts 714-686-1236.
CJD has your best way to go. When I had my head done at the shop (TR6 ) I gave them the head new valves and springs guides so all to match I did grind valves and seats my self and installed all to head 25 years and still running well. NOTE Doing the work yourself has it's own rewards doing it twice is not one of them. Just saying Hope Steve can help. Madflyer
dbenichou289
dbenichou289
Member
Thanks for the info guys. I am working on this with a machine shop and they are letting me be involved in the process. Part of the learning curve is letting me pick out the parts required so I am as hands on as possible. Will reach out to the number listed for additional info.
Madflyer
Very good I did the same. Lessons learned are easily past on as wisdom or caution. When you say DYI people listen. Madflyer
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
N TR4/4A Tr 4a valve seats cleaner Triumph 8
W exhaust valve seats Austin Healey 2
Superwrench valve seats Austin Healey 9
L Valve seats and lead [substitute]. Spridgets 18
PAUL161 Hard Valve Seats, First Year?? MG 6
J hardened valve seats Triumph 11
bluemiata90 Hardened valve seats or not Triumph 6
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
