Hey Guest! BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF helpful, appreciate no pop up ads, and you want to ensure we stay online - Please support us with an "optional" low-cost (less than many car club dues) member upgrade. There are some benefits to upgrading!
Bob,
When I built my engine a few years ago, I had Ford valves and hardened seats put in. I had a machine shop do that, cleanand surface the head and block, oversize and hone the cylinders, and put in and broach the cam bushes. I sent the cam and crank out to be done, and did everything else myself (so truth be known I didn't "do it all myself"). 3000 miles and no problems to date. I'm no expert, but I spoke to some people who are.
Jon, Sounds like you did talk to experts. I guess the Ford valves give you a better valve for the money and better and cheaper keeper design also. I guess hardened seats is the way to go. We can't do it all ourselves. thanks, Bob
Well Bob, if you are going to drive your car hard then uprated valves and seats have been shown to be required.
On the other hand, simple sport driving of the car has not been shown to cause valve / seat erosion.--Fwiw--Keoke
I used a machine shop in Stockton, CA that was recommended by British Car Specialists, I think it was Stockton Machine. I honestly don't know the part numbers used (that's what happens when you DON'T do it all yourself).
BOb:
The PO of my blue over white Healey did not know the difference between 0.12 Thousand and 0.012 so he set the valves to the latter. Consequently, I had to replace them as they were cooked. I used Olds 442 valves machined to be compatible with the Healey's valve stem hardware but only cleaned up the seats. --Fwiw-Keoke
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
