TR2/3/3A Cylinder head removal and valve adjustment
karls59tr
Bronze
When the cylinder head is removed to install a new head gasket and then reinstalled why is it necessary to reset the valve gap? Would the valve gap not still be the same as it was once the rocker shaft is torqued back to spec if no other work had been done to the rocker shaft or valves?
TFB
If your head to block clearance stayed the same with the new gasket compressed exactly the same you would not.
You will need to checkand most likely adjust after install and after reach re-torque of head.
Tom
CJD
You should check valve clearance at least annually. If you are certain you are using the exact same make of head gasket, with exactly the same amount of sealant, then you are correct...you could leave the valve settings. But, it is so easy, why would you not want to, since the valve cover is already off?
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
M Cylinder Head Nut Removal needed Austin Healey 2
19_again cylinder head removal Triumph 6
B Cylinder head removal - 1500 Spridgets 15
M Series III XJ-6 4.2 Liter Cylinder Head removal Jaguar 7
B Cylinder Head Removal Triumph 38
JPSmit A little help please - Cylinder head removal Spridgets 6
George Zeck Cylinder Head Removal Q's ??????? Spridgets 5
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR2/3/3A Cylinder head threaded plub Triumph 6
R BJ8 Cylinder Head Gasket Austin Healey 38
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B General Tech Cylinder head costs MG 7
J For Sale TR 2, TR 3 TR 4 cylinder head Triumph Classifieds 6
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
