Planing a Jaguar cylinder head
MK9NSMAN
I am hoping someone can help me with this machining issue.
I have a MK9 (3.8) head that has been planed and with no record of how much material was removed.
Four questions;
- does anyone have a machine shop reference giving detailed critical dimensions for a Jag 3.8 head and if so?
- what was the thickness of the original finished 3.8 head casting?
- how do you measure the thickness of the finished casting?
- what is minimum acceptable thickness after planing or how much material can be removed?
Any help will be appreciated.
LarryK
I have only planed a couple 3.4 and a 3.8 head. Pretty much trusted the machine shop. Then I checked piston to valve clearance before installing, after adjusting valves. Don't know the specific clearance or shaving, just know I checked piston clearance and only bought recessed pistons on a 3.4. There are different thicknesses of head gaskets. The timing cover has to be shaved to fit the planed head, which can be remedied by head gasket. You might lay head on block and check how much needs to be taken off timing cover, for an answer.
mikespain
Hi, surely the only time the timing cover would have to be shaved is if the surface of the block is shaved not the head?
LarryK
Covering the bases. Cannot see what he has or what was done.
R Planing my built. Stock vs transplant Spridgets 58
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
O Jaguar rear window trim repair Jaguar 1
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
Bristol401 For Sale Jaguar Mk2 Jaguar Classifieds 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
T Motor Jaguar 4.2 Jaguar 14
D 1992 jaguar xjs abs Jaguar 1
L For Sale 1959 Jaguar Mark 1 Jaguar Classifieds 0
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
AngliaGT Jaguar XK120 (?) on I581 Spotted 1
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
Lin Jaguar Distributor Cap for Healey Austin Healey 8
J For Sale For Sale in Seattle, WA: 1989 Jaguar XJ-S Convertible_$11,200 Jaguar Classifieds 1
S SU carbs AUD9124 on a Jaguar ? Jaguar 2
Rut Jaguar 340 Jaguar 8
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
LarryK Jaguar MK1 restorations Jaguar 15
M Jaguar XK Special Equipment Generator Jaguar 1
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
K For Sale Rare Book The Jaguar XK in Australia Jaguar Classifieds 0
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
69MGC Latest Jaguar Digital Illustration Jaguar 0
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
David Townsend Limited Edition Jaguar Puzzles Jaguar 0
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
M Wanted Jaguar XK140 OTS Battery Door Jaguar Classifieds 0
M What is the finish Jaguar Uses on Veneered Trim Pieces? Jaguar 4
nevets Jaguar reissuing the D type. Austin Healey 9
G original radio 1961 e series jaguar Jaguar 3
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
R Jaguar XK140 mystery part Jaguar 0
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
E Series 1 jaguar boot latch problem Jaguar 2
aeronca65t Jaguar event - Lime Rock Racing 3
aeronca65t Priceless Jaguar and Mercedes crash at Goodwood Racing 9
D 1950 Jaguar Mark V Sunroof Question Jaguar 0
C Will Jaguar build a new plant in US? Jaguar 4
K Jaguar 140 Restoration Link? Jaguar 2
C Jaguar Design Director Ian Callum honored for his hard work Jaguar 0
C The 1956 Jaguar XKSS was one of a kind Jaguar 10
C Jaguar wows the crowds at the CES show in Vegas Jaguar 2
M Jaguar XK140MC Carb Etch #'s Jaguar 0
C How will the 2015 Jaguar XF define you? Jaguar 0
