3000 Heater Valve
RonR
Folks,
The heater value at the engine block of my 1959 3000 leaks when the valve is opened.
It seals up fine when closed.
I have been told that all aftermarket valves leak, including those from Moss and AH Spares.
Would replacing the spring on the valve stop it from leaking?
If so, where would one source the spring?
Thanks.
Ron
R
RonR
While it is not really a ball, but more of a tapered cylinder gate valve, I have tried that using graphite.
Healey Nut
Have you tried tapping the pin to seat it once the valve is open ?
Take it apart and clean it really well , look for gouges scrapes etc on the pin and bore , if there are any replace it .
try smearing the pin with a very small Amount of white teflon pipe dope and try again .
I would also try lapping the pin in the bore with fine grinding paste as long as there are no gouges or deep scratches .
John Turney
It is a tapered plug valve. The manufacturers of the new ones don't think customers will pay the extra cost to have them lapped to seal.
As Healey Nut said, lapping with fine grinding paste will help if there are no gouges or deep scratches. Greasing the taper with a heavy grease will also help. There isn't a source for the spring.
Mine is usually stuck after it has been in one position for a long time. I use a pair of pump pliers (AKA channellocks) to push the plug up enough to get it to turn. One might also use them to push the plug down, although the pliers might not fit in the crowded space.
CDK 3000 Heater Valve Austin Healey 4
T Heater/Ventilation Controls on a 3000 Austin Healey 5
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
M Engine Stand for 3000 Motor Austin Healey 7
D Healey 3000 BT7 rear panels Austin Healey 0
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
Guido36 Healey 3000 cutaway display engine Austin Healey 12
pbraun For Sale Healey 3000 transmission Austin Healey Classifieds 8
O HD8 carb on Healey 3000 Austin Healey 62
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
C Austin Healey 3000 in Modsports Austin Healey 4
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
