1962 3000 Hood/Bonnet Grille
  • Thread starter Deleted member 21878
  • Start date
i am trying to get my surround and grill in the bonnet fitting properly. if i just mount the surround, it fits fine. when i add the grill and take up the nuts it twists my surround. Not much but i have some scratches on the side of the scoop that i want the surround to cover... and it does if it fits right.
Looked at the Moss breakdown today and it shows a packing washer that goes between the grill and the surround. (i assume under the hood metal) it does not give a size for the washer. i assume that is my issue with keeping everything fitting properly.
would anyone remember the size of that washer? inside diameter and thickness?
Thanks
Healey Nut
Make sure you use a fibre/plastic/stainless washer . Fibre would be my first choice just regular washer size to fit the stud should work .
But how thick is it?
and does it fit in the grill slot or to it?
thanks
British_Recovery
Bronze
The fiber rectangular washer goes onto the stud first, and is above the slotted holes. The inner grill goes in from below, covering the lower raised flange of the bonnet opening. Then attach with flat metal washer, lock washer, and nut. Do not over tighten.
Thanks again.
hate to keep beating a dead horse but I feel like the thickness of that fiber washer is important. Which is why I ask. Maybe it isn’t a big deal and I am over thinking it.
But just want to confirm.
I was thinking of running a nut up in there before pulling up the grill. Would not only give me a spacer but keep from pulling on the surround stud when tightening.
thoughts?
blueskies
These things are a bit delicate, so it's good to see your cautious approach. I could be wrong, but the main reason for the fiber washer between the chrome surround and the hood/bonnet may be to protect the paint below from chipping or scratching. A nut may be too thick, unless you grind it to a very thin profile first. A small metal washer might serve the same purpose as the fiber washer, except that you run a greater risk of damaging the paint with a metal washer. A small O-ring also likely would work. You seem to understand the importance of not overtightening the nuts, as the studs do separate from the chrome quite easily. If you need to tweak the shape of the chrome surround (they don't always fit great), do the test fitting before installing the nuts.
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
F Road & Track 3000 road test- November 1962 Austin Healey 8
J 1962 3000 MKII BT7 Water pump replacement Austin Healey 3
Patton For Sale 1962 A-H 3000 BJ7 Mark IIa - Plano, TX Austin Healey 2
D 1962 3000 engine Austin Healey 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
G 1962 TR3A inner plate # Triumph 8
C MGA R/H tail lamp removal on a 1962 MG 5
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale MGA Factory Workshop Manuals on CD/ROM - All Models 1955 - 1962 MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
H Estimating a Singer Gazelle IIIC from 1962 Other British Cars 3
D 1962 center shift gearbox cover Austin Healey 7
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
LarryK General TR 1962 Herald Convertible Triumph 10
R Sprite Bonnet Badge 1962 Square Body Spridgets 1
O Wanted 1962 tr4 seat rails Triumph Classifieds 0
S 1962 BT7 transmission shift rail bumber in bell housing Austin Healey 1
C For Sale 1962 Triumph TR3A Triumph Classifieds 3
P 1962 Sprite in Venice, FL Spridgets 0
R TR4/4A Recommendations for Wood dash 1962 TR4 Triumph 5
S My dads 1962 Mk2 Austin Healy finally seeing light since 1981. Austin Healey 4
R 1962 barn find Triumph 9
R 1962 Barn Find Restoration & Tools 7
6 Spitfire 1962 Spitfire, Hood parts &installation info Triumph 7
6 Hood parts and installation instructions for 1962 Triumph 1
Anthony_S Post-War Other 1962 Herald Triumph 4
Marvin Gruber 1962 OTS XKE Jaguar 11
me61ic 1962 BT7 for sale in NY Austin Healey 0
C 1962 Austin-Healey BT7 value? Austin Healey 17
V 1962 BN7 Price Austin Healey 4
J AH 1962 - Putting on Front Fenders Austin Healey 8
V 1962 E-Type Jaguar 14
D TR4/4A 1962 TR4 - For Sale in Montana Triumph 3
M 1962 AHS ebay Spridgets 3
AUSMHLY Astro hard top for 1962-1968 Healey Austin Healey 7
C I found a 1962 today! Spridgets 4
af3683 TR2/3/3A TR3B - Register it as a 1962 or 1963? Triumph 19
