TR5/TR250 Bypass valve
mrw02536
I’m rebuilding a set of stromberg cd-2 175 carbs. The vacuum inlet on the bypass valves have been soldered closed. Should I reopen them or use them shut off? I will be installing the carbs on a tr250.
poolboy
Are you talking about the brass nipple like the TBV on the left in this picture or where it opens inside the valve ?
M
mrw02536
Are you talking about the brass nipple like the TBV on the left in this picture or where it opens inside the valve ?View attachment 79921
I also have another question about the gaskets that came with the diaphragm kit. I replaced the diaphragm and used one of the gaskets between the carb body and bypass valve, what are the extras for?
M
mrw02536
As I’ve said, as a project I purchased a set of cd-2 175 to rebuild. My 250 is in storage in Florida until I get there on December, when I’ll install the rebuilt ones. I dissembled the carbs completely and just waiting for parts to reassemble. I needed to replace the jet and adjustment screw as well as the throttle shaft and seals which were quite worn. The diaphragm in the bypass valve was brittle. Naturally all new gaskets and o-rings. Everything was cleaned in chemdip. The carbs are a slightly later version of what on my car, having adjustable needles and a plug in brass drain. Every else looks the same. This is my first and I wonder if there are any last minute things I should be aware of. I don’t no what to expect when I install them.
poolboy
If you want to keep the TBV functional you may find a variety of gaskets in the kit. the one you'd use with that version of the TBV is the one in the middle.
Personally I prefer to disable it's function entirely....an be done with it.
M
mrw02536
Now I’m confused. From the photo, vacuum from the photo gets to the carb through the small hole that fed by the brass tube that you suggest i cover with the gasket. What do I have wrong? It looks like the one on the right is the correct fit.
poolboy
The type of TBV that was used on the TR250, the 69TR6 and the 74 TR6 is like the one you have..The sensing port for the vacuum that makes the TBV function is a hole down at the bottom of that nipple.
On the rest of the years the sensing port is internal and must remain open if you want the TBV to function,
BUT. the small hole gets covered in the 250, 69 and 74 versions
This 69 TR6 illustration is exactly the same as the TR250
I'd disable the thing entirely if I were you...make a substantial gasket,one capable of standing up to high manifold vacuum..in excess of 25 in-Hg during engine braking..a gasket that covers all but the 3 threaded screw holes that attach the TBV to the body of the carb.
M
mrw02536
This is how I currently have it blocked.
M
mrw02536
If you can tell me why you think it's needed ?
Bypass Valve: The bypass valve provides a channel for air to flow around the throttle disk. A very high depression can exist in the intake manifold if the engine is operating at a high RPM with the throttle closed such as might occur when decelerating. Poor fuel combustion occurs in this situation giving increased exhaust emissions. This is frequently evidence by exhaust popping during deceleration. The bypass valve senses the high depression and allows some air to go around the throttle plate to reduce the depression to the desired level.
poolboy
Right...the reason I disable it is because it's emission related only under those rare conditions that it opens.
Disabled, I don't have to bother with the procedure for getting it properly adjusted and the idle will never be affected by a bad adjustment or by the inevitable deterioration of the TBV's diaphragm
BUT if you have a 250 (or a 69) it's important to not only have the TBV properly adjusted but also the Vacuum Control Valve that's mounted and activated by the front carb which must be installed and also properly adjusted.
If you have all that and feel the need for the TBV to function when you use 'engine brake' then do not deactivate it.
M
mrw02536
This is what i read:
what is the downside if everything is working properly?
A T-Series MGTD oil pump bypass valve MG 0
L TR6 Bypass valve adjustment Triumph 1
sundown TR6 1973 TR6 bypass valve Triumph 1
wangdango TR6 '76 TR 6 stromberg bypass valve? Triumph 1
jerrybny Bypass Valve Assembly Triumph 2
Doug Sabbag TR6 Ammeter blown.. bypass? Triumph 10
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
Gliderman8 TR6 Rheostat bypass Triumph 1
S TR6 Stromberg Bypass Valves - Question Triumph 11
R TR2/3/3A Thermostat and bypass hose Triumph 15
C TR6 Seat belt warning bypass for new harness. Triumph 6
T TR2/3/3A Water Pump Housing Bypass Triumph 11
B TR2/3/3A bypass hose Triumph 11
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
P 1275 bypass hose???? Spridgets 5
L TR2/3/3A bypass hose Triumph 3
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
D Overdrive bypass switch Austin Healey 1
K TR2/3/3A Paging TR3driver re blocked bypass and Shaller pdf Triumph 1
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
E 1275 Water bypass nipple Spridgets 11
V ZS Carb Bypass Done Triumph 1
V TR6 TR6 ZS Bypass kit Triumph 18
R Bypass hose... Spridgets 7
19_again Gas bypass-low rpm's MG 5
A bypass vs no bypass Spridgets 10
E 1275 Cylinder Head Bypass Nipple Spridgets 4
Paulus Stromberg bypass issues Triumph 4
K TR2/3/3A TR3 Cooling...Blocking the Bypass Triumph 5
B T-Series bypass hazard switch MG 17
Y Oil pressure ignition bypass MG 3
J TR4/4A TR3, TR4 bypass hose needed , NAPA #? Triumph 2
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
