wangdango
Just got the parts from Moss, gather the gasket wbronze valve is sandwiched between the two other similar gaskets. BUT, the kit also came with a very small flat '"o" ring, where does this go? There are also two smaller, gaskets for where the bypass valve mates to the side of the carb, these two gaskets are different, which is the correct one for a late '76 TR6? Also, what should the bypass valve be "set/started at?"
thanks again!
ed
thanks again!
ed
