J-H Stromberg carb connections? Where do they go?
Ray Brandes
Member
In an effort to get it plumbed correctly, I have taken some photos to suppport my questions;
I know this is a vacuum line.
And this vacuum goes to the distributor.
What is this gadget with two spigots? Where do they go to?
I jumped these to the vacuum port in the first photo. Please advise!
Two brass pipes looked like they wanted to be connected. Is that correct?
I plugged these vacuum ports. Where do they go?
Thank you all for your help.
Regards, Ray
Platinum
The "two spigots" thing looks to be a hot water choke. Ignore it (we're in Florida!). "Whatisit2" is a by-pass valve, emissions device to limit excess fuel going to atmosphere on deceleration. Controlled by vacuum on the rear carb in "jumper.jpg".
"Morevacuum" should have one line going to the charcoal cannister, IIRC.
Haven't seen or worked on J-H since the mid-eighties, then only a couple came through the shop. The 907 Lotus cars we worked on were converted to Weber or Dellorto carbs.
JPSmit
Ray, PM me your email address and I can send you a PDF of a Stromberg manual - It might not go into the detail you need as per Doc's responses above, but if you can use it you are welcome.
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
R GT6 Carb Floats for Stromberg 150 . Triumph 5
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
H Stromberg Carb Sync and adjust Triumph 6
JPSmit Stromberg Carb Question Triumph 15
A XKE Series II Stromberg Carb Upgrade Jaguar 4
S Question on rebuilding Stromberg carb Triumph 24
T Stromberg 150 CD carb question Triumph 4
C Stromberg Carb 'O' ring Triumph 3
dklawson Improvising Stromberg Carb Tools Triumph 14
J TR4/4A TR4 Stromberg Carb Question ? Triumph 12
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
P GT6 GT6 stromberg carb question Triumph 6
SCguy TR4/4A TR4 Stromberg Carb. adjustment Triumph 12
M Stromberg Carb Problem Triumph 5
K Stromberg carb question Triumph 4
S stromberg carb adjusting Triumph 2
Got_All_4 STROMBERG NEEDLES FOR 3 CARB SET UP Triumph 2
johnrip Zeinith-Stromberg Carb K+N Air Filters Triumph 8
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
