Zeinith-Stromberg Carb K+N Air Filters
johnrip
If I were to install a K&N, or other after market performance air cleaners on my 1980 tr7, would I have to make adjustments to my carb needles? /ubbthreads/images/graemlins/savewave.gif
There are differing opinions on installing the K&Ns over the original airbox setup. On some Spits and GT6s with dual carbs, the airbox had hoses that vented to the front of the radiator where "cold" air was available to the carbs. Colder air = more horsepower/better combustion.
The engine bay of these cars can become pretty hot. The K&N setup and other aftermarket setups suck air directly from one of the hottest areas in the engine bay, just above the exhaust manifold. Also, the K&Ns provide a different airflow rate and speed to the carbs than the original setup.
So, do you need to adjust the needles with K&Ns? Depends on what you're trying to accomplish. Some folks say adjustments ARE needed. Others say no.
I'd like to believe that the Triumph engineers knew what they were doing with the "cold air" setup.
My humble advice: keep the original setup, especially if your engine is stock. It looks "correct" and allows the engine to function as it was designed to do.
Now that I think about it, I'mm pretty sure you can get a K&N element that is the same size as a stock paper filter. That way you can install them in the original air box.
My GT6 has regular K&N filters on it, and no needle adjustments were necessary.
Jeff
Yup, I have a GT6 airbox with 2 K&N's with the hoses on the Sports 6, I didnt change the springs either.
Good luck
Did you want pic's of the car or the carb setup?
I had a pic in the member rides...But I cant find the link...I will look harder.
The car. I saw my first Sports Six at the Richmond VTR show last month and fell in love with it. It was Jim Williams' jet black convertible, I think it's been on sale on EBay a couple of times for $28K.
A mostly forgotten Triumph in the U.S. since not many were imported. Our loss!
Hi Mark.
I hope im not high jacking this post but here is a pic from the readers rides, Mine hasnt changed much since we bought a newer vehicle, Mine(red) is parked next to a SWEEEEET black Sports 6 at our British Feild day.
https://www.britishcarforum.com/PHPhotoalbum/displayimage.php?pid=596
I will need to look for a few others if needed, Here is another link to a Triumph site specific to the Herald/Vitesse cars, The owner is our your way in NY.
https://members.aol.com/_ht_a/herald1200/database/index.html?mtbrand=AOL_US
Have fun
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
R TR4/4A Tr4a, Stromberg float setting Triumph 6
regularman I found the fix for the stromberg on the 1500 Spridgets 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
C Stromberg carbs Triumph 8
