Stromberg carbs
C
countennis
I have installed in my TR250 two Stromberg carbs that were previously overhauled by Gary Martin. I have balanced the carbs.
I discovered that the fuel mixture was very lean in both carbs.
I have the correct jet adjusting tool, but the diaphragm tube on both carbs don' have the notch for the jet tool to lock into.
Also, when turning the hex tool it always just turns around and around. The hex never engages the jet. Any ideas?
Thanks,
Jack
M_Pied_Lourd
Hi jack
I believe that the early as carbs have fixed non adjustable needles. I am sure that the carb experts will jump in here.
Cheers
M pied Lourd
TR4nut
Not sure what would be correct for a TR250, but on the TR4 which has fixed needles the mixture is adjusted by moving the jet from the bottom. If you have a large adjustment screw on the very bottom of the carbs you likely have that setup.
Geo Hahn
In case you are unsure which carb you have... this is what the early Strombergs looked like:
They are adjusted by turning that 'nut' (item 26) -- has a slot so they can be turned using a quarter (or I prefer a 2 shilling coin).
Carbs in situ...
TR3driver
Great Pumpkin - R.I.P
As Pied suggested, the TR250 and early TR6 carbs had no adjustment for mixture, beyond a very small air bleed (aka "idle trim") screw.
There are several ways to gimmick them, including sanding down the needle and moving the jet a bit lower in the housing. But the best solution IMO is to source the pistons (or complete carbs) from a later car, with the factory adjustment inside the dashpot.
I believe the Buckeye site still has the article on how to modify the early pistons, but it looks like a lot of work and you still need to source several parts from a later carb.
OTOH, they shouldn't be "very lean" unless something is wrong. I'd be looking for something outside the carbs, like maybe a leaking brake booster or weak ignition system.
C
countennis
Thanks!
I don't think it is an ignition problem as I have a Petronix
setup.
Will check the vacuum situation. Don't think it is a booster leak, but I do have the rest of the vacuum ports blocked so I will check all of those.
70herald
Hi Jack
While you are adjusting the mixture on the bottom of the carbs, which raises or lowers (which is what you need in order to get a richer mixture) the jet.
Here is something to think about from the humor section: :jester:
As he stared at her ample bosom, he daydreamed of the dual Stromberg carburetors in his vintage Triumph Spitfire, highly functional yet pleasingly formed, perched prominently on top of the intake manifold, aching for experienced hands, the small knurled caps of the oil dampeners begging to be inspected and adjusted as described in chapter seven of the shop manual.
--Dan McKay, Fargo, North Dakota (2005 Winner)
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
L zenith-stromberg carbs Lotus 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Zenith stromberg carbs Jaguar 3
sundown 175cd stromberg carbs Triumph 4
glemon Rebuilding stromberg Carbs Throttle Shaft Bushings Triumph 6
T Gas leaks from the bottom of my Stromberg carbs. Triumph 7
T Triumph Stromberg carbs leaking from caps on botto Austin Healey 2
TR4 Stromberg Carbs Overflowing Triumph 5
M Help with Tuning Stromberg 175CD Carbs in Houston Triumph 37
TRnorwegian I'm installing Stromberg carbs, selling my Webers Triumph 11
glemon Stromberg Carbs Triumph 18
martx-5 Zenith Stromberg Carbs Triumph 4
Phil73 Lotus and Stromberg carbs Lotus 3
wangdango TR6 '76 TR6 stromberg carbs.. Triumph 8
wangdango TR6 '76 TR6 stromberg carbs.. Triumph 3
H stromberg carbs....150cd and 175cd...diffrence? Other British Cars 7
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
glemon Late Stromberg Carbs MG 6
bravenrace Where to Get Stromberg Carbs Rebuilt? Triumph 16
bravenrace Need Help With Stromberg Carbs Triumph 11
martx-5 SU and Stromberg Carbs on Modified Motor Triumph 5
P Stromberg CDSE emmission control carbs Triumph 3
77_MG_Midget Zenith Stromberg Carbs Spridgets 6
H stromberg 175 carbs Jaguar 1
TR4 Tuning Stromberg Carbs ???? Triumph 7
TR4 Converting from Stromberg to Weber Carbs? Triumph 23
TR4 Stromberg Carbs Triumph 13
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
