TR6 1974 tr6 stromberg 175 cd-2 choke
H
HelpingTRresto
1974 tr6 twin choke cables. solid wire cables will pull chokes on but not push them off. I have tried different adjustments to both inner and outer case. Should I go ahead and replace the cable assembly? is it normal for these choke levers to not have a return spring? Thanks for help.
poolboy
From the factory...pre 73 cars had choke cables that were mutli stranded and very flexible...because of that there were return springs on the choke fast idle cam...and a twist to lock choke cable knob to keep the choke engaged at whatever amount you want or need.
From 73 on the choke cable had a single stiff wire that was capable of not only pulling the choke fast idle cam UP/ON, but also stiff enough to push the choke DOWN to an OFF position.
You can purchase the spring and install it on the post 72 chokes...I have a spring on ONE of mine to help keep the chokes OFF.
H
HelpingTRresto
Thanks very much. I had an idea that may the reason for no springs. I seem to have a binding cable. My friend got the car recently, and only 1 cable was connected. I will proceed. I may have a spring to try.
P TR6 Horn issue 1974 TR6 Triumph 5
A For Sale 1974 TR6 Triumph Classifieds 1
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
H TR6 1974 tr6 allison xr700 Triumph 12
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
G TR6 1974 TR6 distributor advance spring specs Triumph 6
2 TR6 Price Reduces on 1974 TR6 W/Ovewrdrive. excellent Triumph 0
TR6BobNF TR6 1974 O/D TR6 For Sale in Newfoundland Triumph 1
I TR6 1974 tr6 Triumph 2
W TR6 Tr6 1974 Distributor Triumph 7
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
T TR6 1974 TR6 coil question Triumph 3
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
2wrench TR6 Which water pump for my April 1974 TR6 Triumph 3
2wrench TR6 1974 TR6 Engine Rebuild and/or Repair Triumph 26
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
T TR6 Swapping 1974 TR6 fenders on to my 71 TR6? Triumph 5
D Trying to get back working on the 1974 Midget Spridgets 11
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
VeeCee MGB 1974 MGB Roof Installation MG 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
J 1974 Jensen Other British Cars 22
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
P MGB 1974 MGB front spring length. MG 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
A MGB MGB 1974 windscreen centre rod replacement MG 5
R SOLD!! 1974 Jensen Healey Other British Classifieds 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
krswen For Sale 1974 Panther J72 Other British Classifieds 4
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
A 1974 2500M Spring Rates TVR 6
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
B 1974 Midget Spridgets 6
jmayzer For Sale 1974 MG Midget Mk III [Maryland, USA] Spridgets Classified 1
J MGB 1974 1/2 MGB gasoline type MG 5
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
