MGB MGB 1974 windscreen centre rod replacement
Aussie Chris
I recently replaced the rusty centre rod attached to the windscreen by taking off the revision mirror and drilling out the four pop rivets which allowed me to unscrew the rod and put in a new one then re rivet it back the question I have is how tight do you do up the rod?
Regards
Aussie Chris
Mickey Richaud
Hi, Chris -
As I understand it, that rod is primarily in place to keep the top rail of the windshield from lifting when the top is secured. Probably most prudent to install finger tight, then a couple flats more with a suitable wrench. Maybe a bit of Loctite to keep it from backing out.
PAUL161
Chris, don't over tighten it, try to get the same pressure in the center as is overall. Mickey's suggestion is right on! PJ
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
VeeCee MGB 1974 MGB Roof Installation MG 0
P MGB 1974 MGB front spring length. MG 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
J MGB 1974 1/2 MGB gasoline type MG 5
wkilleffer MGB 1974 MGB convertible top anchor bar size MG 4
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
wkilleffer T-Series Clutch pipe installation- 1974 MGB MG 2
N MGB 1974 MGB Questions MG 5
K T-Series Trailer Hitch for 1974 MGB Roadster MG 4
Monark192 MGB 1974.5 MGB vs. 1975 model. Which to keep? MG 19
wkilleffer MGB 1974 MGB distributor drive dog- which one is it? MG 8
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
wkilleffer MGB MGB 4-way fuse box question- 1974 MGB MG 8
C MGB-GT 1974 1/2 MGB GT MG 37
1 MGB 1974 MGB in Florida MG 15
M T-Series 1974 mgb ignition switch/lock w/harness MG 10
7 MGB My Project Car 1974 MGB Convertible MG 50
C MGB 1974 MGB ready for lots of work and help with questions:] MG 6
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
