T-Series Clutch pipe installation- 1974 MGB
wkilleffer
Hey everyone,
Before entering this topic, I tried searching for it, but wasn't able to find exactly what I was looking for. So, here goes...
It appears that I've finally got all the parts together for repairing/replacing the clutch hydraulics on my '74 MGB.
The clutch pipe runs from the master cylinder to a body fitting where it fastens to the rubber flex line. It's not a straight linear path.
The new pipe that I received appears to be some kind of copper alloy but doesn't feel as malleable as copper tubing from the hardware store.
Now, the original pipe has some bends and straights on its way from master cylinder to flex line. What I received was shipped in a coil. Will I need a pipe bender to bend it properly? I sure don't want to break it.
Any advice and suggestions would be appreciated.
Thank you,
-Bill
Mickey Richaud
Hey, Bill -
I've done them by hand and with a bending tool. Breaking is less an issue than kinking them. If the bend is a slight one, you can do it carefully by hand, and I find it easier to match the bend that way. Ninety-degree bends in a short radius is better left to using a tool. Warm the tube up beforehand, either way.
Let us know how you make out.
:cheers:
Mickey
Platinum
THIS one works well for all the "plumbing" we've done.
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
K TR4/4A Adapter that connects Clutch MC to the pipe that goes to the slave cyl? Triumph 4
N TR4/4A clutch pipe Triumph 0
E TR4/4A TR4 Clutch pipe route Triumph 2
sail TR4/4A 4A Pipe from Clutch Master to Hose Triumph 4
W Brake and clutch pipe orientation Spridgets 4
martx-5 TR2/3/3A TR3 Clutch Pipe Triumph 9
VelodromeRacer Thread size and pipe size for steel clutch line... Spridgets 2
X T-Series Sooty exhaust pipe & loosing clutch fluid MG 0
ncbugeye Dumb location for clutch pipe stress relief coil Spridgets 2
martx-5 Clutch Hydraulic Pipe Routing Triumph 5
jhorton3 Clutch Pipe Adapter Spridgets 5
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
