STROMBERG NEEDLES FOR 3 CARB SET UP
Got_All_4
LOOKING FOR THE CORRECT NEEDLES TO GET STARTED. DOING GOOD PARTS TIPPLE CARB SET UP AND HAVE A SET OF 1971 CARBS. I FOUND OUT THAT ONE OF MY PISTONS DOESN'T HAVE THE ADJUSTABLE NEEDLES BUT I HAVE A SET OF 3 ADJUSTABLES FROM A MGB FOR A COMPLETE MATCH SET. HOWEVER THE B NEEDLES ARE ABOUT 5K THICKER. I INCREASED COMPRESSION TO 10:1 AND HAVE MILED STREET CAM, SO I BELIEVE I WOULD WANT TO GET MORE FUEL INTO THE CYLINDERS. ANY SUGGESTIONS.
Simon TR4a
I am hoping someone who has this setup will answer your question.
Since I have not get a TR6 my answer must be taken as a suggestion only!
My guess is that the stock needle for a TR6 would be a good place to start, because you are still only filling one cylinder at a time, whether you use 2 carbs each filling 3 cylinders or the other way round.
The range of adjustment at the bottom of the carb should allow you to compensate for the mild cam.
Again, I am guessing; someone who KNOWS would better answer your question.
Simon, (trying to separate facts from opinions.)
Rick O.
Why not simply ask the expert himself, Richard Good?
S TR6 TR6 Stromberg needles Triumph 2
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
R TR4/4A Tr4a, Stromberg float setting Triumph 6
regularman I found the fix for the stromberg on the 1500 Spridgets 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
