Oil pressure ignition bypass
Yeahbaby
Member
OK MG boys, now is the time to help a fellow LBC(TRIUMPH) owner.
About a year ago I was surfing and saw a website with a kit which would allow the starter to turn the motor over but not let it start until a predetermined oil pressure was made.
It was in a kit form.
Anybody remember such a kit?
One of the advantages of a hard starting car is that there is always oil pressure by the time it finally fires.
Seriously, quite a few cars have a low oil pressure fuel pump shutoff Which you could use for this. I'll bet that your local car parts store has something. I used a General Automotive #23470, from a 1980 Dodge Omni For a fuel shutoff.
[ 02-26-2004: Message edited by: Dave Russell ]</p>
wouldn't be too hard to cobble up, just put a tee in the block where the oil pressure line mounts and mount a pressure switch on the extra arm. run the wire to the coil across the contacts on the pressure switch and you're good to go. It would also have the added benefit (?) of shutting down your engine if the oil pressure dropped. This would require a setting below the hot idle oil pressure or you'd have trouble at every stop light
That's brillian thinking! Something for GEM? I can think of at least one person who overtightened the hanging oil filter unit, which caused it to break, dropping the whole mess onto the road. He was quick at the key, I wouldn't even have noticed.
Musicman Oil Pressure and Ignition Lights Triumph 13
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
G Need Help: Oil leak/crankcase pressure Spridgets 18
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
