TR2/3/3A Oil pressure at Hot idle?
karls59tr
Bronze
Lately my oil pressure gauge is reading 70 psi ? Better than reading too low but I don't remember it being that high. Maybe 50psi? Engine rebuild was around 15 years ago. Could there be something else going on or is this a gauge issue? What should normal oil pressure be during driving and after a hard run?
DavidApp
My oil pressure is 20 to 25 at idle when hot and 50 to 60 at 2500 rpm hot. On startup it is 70.
I did reset my Pressure relief valve to 70 psi.
The TR3B I am working on had an oil pressure around 90 when I drove it up the road so I reset it to 70.
You could get a cheap gauge to plug into the oil pressure line to verify your gauge.
David
CJD
If the gage does not return to zero when you shut down, then your gage is sprung. If it does return to zero, then either the gage is correct, or needs calibration.
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
G Need Help: Oil leak/crankcase pressure Spridgets 18
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
