MGB Oil pressure
Aussie Chris
Hi to all
My 1974 MGB from cold start has oil pressure 80psi and usually stays around that mark . It has increased up to 90 psi after engine got warm should I be worried ? Engine was totally rebuilt with new oil pump about 12 months ago
Regards
Aussie Chris
YakkoWarner
To me that sounds almost too high; especially if it goes UP after warmup. Rebuilt engine and new pump should put out good pressure, but going up after warmup sounds odd. Did they go back to an actual plumbed pipe pressure gauge in 1974 or does it still have the electrical sending unit (my 1970 has the electrical unit, I know in 1977 they used a plumbed pipe). I'd consider hooking up a mechanics' oil pressure test kit and verify that the dash readings are what the engine is really delivering. If it is, verify there is no blockage in the external lines or in the oil cooler?
Platinum
Hi Chris. On cold start 80psi is not unusual in a fresh engine, but you should see a drop after it gets to normal operating temp. Someplace around 40-ish at idle and 60 on revs. over 2K. As Yakko suggests, a blockage in cooler lines is possible. I'd think more along the lines of a too-strong spring (or too many shims) in the pressure relief valve. Just be aware that spring and cap are a real bugger to push back in far enough to start the threads when the engine is in the car.
Platinum
Forgot it may be electrical OP gauge. A "hard" mechanical gauge would be a good first step.
A
Aussie Chris
Have you by any chance filled with fully synthetic oil, as this thickens when it gets warm.
Just normal Castrol 20 50 now that I am paying attention to it the pressure on cold start goes to 80 then basically
stays their it will vary 10 either way depending on what you are doing
A
Aussie Chris
Hi Doc ,
I read that some oil filters because don’t have much space between the the feed pipe and the top of the filter can create higher pressure does it sound feasible if so I am using a coopers wz89 filter at present do you think it’s worth replacing ?
Aussie Chris
PAUL161
Chris, Try doing the easiest first, such as changing the filter with a different brand if that doesn't lower the pressure check with a hard line mechanical gauge to see if your electrical gauge is out of calibration. The last option, because it's a PITA, would be to change the bypass spring pressure. If none of those work you have a blockage somewhere.
A
Aussie Chris
Hi Doc,
Hope you had a great festive season, finally with nothing to do so I reconnected the old smith gauge to check oil pressure
65 to 70 on start up and 70 to 75 after warm up and on the road running between 50 to 60 mph . The new Smiths gauge from England was showing 95 psi under same conditions so all good just not impressed with new gauge and talking to supplier.
Regards
Chris
Platinum
Glad to learn it's not your engine! 👍
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
G Need Help: Oil leak/crankcase pressure Spridgets 18
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
