TR4/4A Oil pressure gauge Line?
karls59tr
Bronze
Anyone know where I could get the line/tube? that connects the gauge from the mid point connection up to the gauge? Actually I have the bottom part of the tube after the mid point but I am missing the female brass connector that attaches to the male end at the back of the gauge and about 2' of tubing. Is there a source for these connectors...appear to be fine thread.
TR3driver
Great Pumpkin - R.I.P
TRF has the pipe listed, 202980.
IIRC the nut uses oddball threads.
Don't forget you need a seal between the end of the pipe and the gauge. Original was leather, but I used a small nylon flat washer instead. It should fit over the little nub on the gauge fitting.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
M Oil Pressure Gauge Triumph 0
