Oil Pressure Gauge Pipe Fitting
erstearns
Does the pipe fitting on the gauge require a washer or is the seal made between the flat brass surfaces? Don't see a washer listed on any of the parts diagrams but have seen a washer mentioned on various threads.
dfwip
Eric-
On the later cars it is a leather washer.
My bet is that it is the same on your car.
Moss UK has them. Not sure about Moss USA.
Paul
Whitephrog
The Austin Healey Sprite Service Parts List dated June 1960 doesn't show or list a washer.
E
erstearns
Found some fiber washers at the local hardware store that are the right size, although seems like the brass to brass faces would seal if they were smooth. Neoprene would work also I guess. Just don't want engine oil all over the pretty new white paint in the interior.
dklawson
To the best of my knowledge, the sealing washer was used on Smiths mechanical oil pressure gauges regardless of when the gauge was made and what make/model of car it was used in.
As above, you can make them from many materials. The only caveat is don't be tempted to use an o-ring. While the o-ring might work at first, they have a tendency to slip outward over time under the oil pressure.
If you are ever installing a completely new oil pressure tube/line, you can use the generic copper line kits that come with a female 1/8NPT pipe to tube compression fitting. Though the threads aren't the same as on the gauge, a few wraps of Teflon tape and the NPT fitting will work perfectly.
E
erstearns
I have a new copper line from the gauge and it has the flat faced fitting. Will use fiber washer.
Whitephrog
Today started the engine in the new Whitephrog for the first time in five years. Oil leaked around the oil pipe fitting at the back of the dual gauge. Don't remember putting a washer there when I assembled the dash but I will be doing that soon.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
M Oil Pressure Gauge Triumph 0
