Bugeye Oil Pressure Gauge
erstearns
Can someone help with my oil line fittings? Have searched previous posts and cannot find what I am looking for. I have a 1/8 steel line with a brass fitting on one end and some sort of ferrule on the other. The brass fitting end seems to match up nicely with the gauge (with a washer in between?)and the ferrule end seems to fit into the concave end of the engine block fitting. However, Moss notes that the brass fitting and nut go on the engine end of the line.
Which end of the fitting goes into the block, flat side or concave side with short threads? Which way does the pipe go? Seems that in either event I am missing two nuts and at least one washer. What do they look like and where can I get them?
I know that the hard line should be coiled to reduce vibration and that a piece of flex may be necessary.
spritenut
There is no coil in the oil pipe, and the small end is where the flexible rubber hose goes.
It's about 8" long, then on the engine is a small 90 degree (or so) nipple with a bulge for the hose and a fitting for the block. There should be a 3/8 x 24 thread nipple coming out of the block where the 90 screws to.
E
erstearns
I have a 1275 installed and there is no threaded nipple but there is a spot for a male thread to be screwed in to at about 5 o'clock down from where the oil supply line is. Maybe I have the wrong fitting (think came from VB and listed as "union oil pressure valve"
Here is what I have.
E
erstearns
I found what I think is correct at AHSpares. 3 pieces, engine fitting metal to flex, flex, flex to metal gauge.
E
erstearns
Thanks Ray. What I have is one end, I think the gauge end that the PO had straightened. I think the pieces I have ordered should allow me to install as your pics illustrate.
R Bugeye oil pressure line Spridgets 9
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
T Oil Pressure-Bugeye Sprite Spridgets 12
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
I Bugeye oil leak help Spridgets 4
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
I Bugeye oil pan help Spridgets 3
I Bugeye dash pot oil level Spridgets 3
M What is the proper oil for Bugeye engne and transmission Spridgets 6
M Oil filter on Bugeye question Spridgets 4
Rut Bugeye oil leak Spridgets 8
P Bugeye Water/Oil Combo. Gauge? Spridgets 4
P Bugeye oil/water gauge? Spridgets 6
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
DanLewis Other ways to mount an oil cooler on a Bugeye Spridgets 3
I oil/oil additives for stock Bugeye engine? Spridgets 10
Kurtis 1275 Oil Filter Change on a Bugeye... Spridgets 10
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
