Bugeye dash pot oil level
ichthos
After my Bugeye sat two years, I am embarrassed to say I have forgotten how much oil to put in the carb dash pots. Can someone help me? Thanks in advance, Kevin
JPSmit
enough. :grin:
This is not an exact science - pour some in (1/2 fullish?) the plunger will push out any surplus.
dklawson
The carb will have a metal tube attached to the top of the moving piston. Fill that metal tube to within about 1/4" of its top. When you fit the brass dashpot back to the carb, any excess oil will overflow the inner metal tube, get sucked through the carb and burned.
longbridgehealey Bugeye dash Spridgets 6
I Bugeye dash light problems Spridgets 9
TulsaFred Bugeye radio in-dash Spridgets 10
Editor_Reid WTB Bugeye Dash Knob Set Spridgets 13
D Bugeye dash vinyl Spridgets 19
L Bugeye dash indicator assembly pieces ? Spridgets 0
F Wire insulation damage under the dash - Bugeye Spridgets 5
TulsaFred Source for Bugeye dash/switch bezel nuts Spridgets 9
TulsaFred Bugeye dash grab handle Spridgets 6
TulsaFred bugeye windscreen washer pump dash fitting Spridgets 10
60Bugeye Bugeye Dash Help Spridgets 23
I Bugeye - need help with last 3 dash wires Spridgets 7
M Building Bugeye dash Spridgets 28
toysrrus "WANTED": "ORIG. BUGEYE SERVICE MANUAL" & `59 DASH Spridgets 7
W Will a Bugeye dash fit Spridgets 12
John Moore Bugeye Seat Bottoms / RHD Dash Spridgets 1
Shealey Anyone have a dash grab handle for a Bugeye? Spridgets 17
Shealey Need a photo of a unmolested dash. 58/59 bugeye. Spridgets 25
msoylemez original bugeye dash items Spridgets 27
F Bugeye dash color Spridgets 5
B Bugeye Dash Covering? Spridgets 4
G Install Bugeye dash in my 67 Midget Spridgets 0
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
