Wire insulation damage under the dash - Bugeye
Fred_Maves
Member
While inspecting the maze of wires beneath the dash of my Bugeye I uncovered a few wires having had the insulation melted in spots. I suspect that the coiled wire lead to the temperature gauge was the possible source of the problem. Could this be true? If so, is routing the wires well away from the temp lead the solution -or- is there a way to further insulate the temp lead from the possible random contact in the future?
Sarastro
That lead doesn't get hot. The gauge works on the pressure of a volatile substance in the bulb, and the lead just carries the pressure. If it is getting hot, there is a real problem, maybe the engine-to-body ground cable is missing.
It's hard to say why the insulation would melt in small areas. Maybe someone was under there with a soldering iron at some point, or something else hot. In any case, if it's short, you can cut out the damaged section and reconnect it with a crimp connection or (my preference) solder it and cover with heat-shrink tubing. I don't recommend taping it, as electrical tape gets gooey and comes loose after some period of time.
F
Fred_Maves
Member
Steve,
Thank you for your quick response. I am unsure about the ground issue here, but I will certainly make sure to include a ground connection. As for the other possible scenarios, there may have been any number of bumbling DIY guys under there before me.
- Fred
Sarastro
There should be a heavy uninsulated cable under the car between the engine/transmission and the body. If it's not there, the high current for the starter will go through whatever path it can, and that often is the tube for the temp sensor. Then, for sure, it will get very hot, maybe melt. It's worth checking to make sure that cable is in place; it's usually connected to one of the transmission bellhousing bolts and is visible by looking under the car. But as long as there is a heavy cable somewhere from the engine to the body, you should be fine. You're probably OK, but still, it's a simple thing to check.
F
Fred_Maves
Member
Thank you for your definitive example. Being that my car is the culmination of several junked versions, the strap in question must have been removed on the engine/trans. I ended up with. I'm making up a strap as we speak.
Thanks once more.
bug_sixty
oops A time long ago I managed to short out the rear tail light wires which fried the wiring all the way to the dash switch before I cut the juice. A sad day.. Why the breaker didn't do its job I have yet to figure out
memphis Braided Wire Insulation Austin Healey 12
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
KLUTZ Wedge FASD wire question Triumph 1
P TR5/TR250 Wire wheels width Triumph 8
P Wire Wheel Splines Austin Healey 10
KVH General Tech O/D Electrical Wire Burned Triumph 22
D Wire Wheels and Air Leak Austin Healey 16
S TR2/3/3A wire repair Triumph 7
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R General TR Emergency hot wire - because you never know whats next Triumph 2
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
S MGB mystery wire MG 32
RJS General TR Wire Wheel Spline Question Triumph 3
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
steveg TR6 Steering boot clamp wire - why? Triumph 2
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
B TR4/4A Wire wheel question Triumph 10
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
T Location of ground wire for BJ8 Austin Healey 6
C What to do about my wire wheels Restoration & Tools 6
P TR5/TR250 wire wheel question Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
K TR2/3/3A Yellow wire uprated condensor Triumph 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Leatherman TR2/3/3A Wire wheel conversion question Triumph 19
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
Rut TR4/4A MWS wire wheels Triumph 9
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
Tullamore Rolls Royce Phantom III Wire Harness Other British Cars 1
I TR6 Gauge/color wire ? Triumph 9
N Enrichener [choke] wire Austin Healey 1
