MGB mystery wire
Svcmangler
Member
Good morning everyone. I have a 1978 MGB with a mystery wire that is in the loom that goes to the temperature sensor. It is a heavier gauge than the temp sensor wire, but is also dark green. It has power after the key is turned on. Anyone know where this might go?
  • mystery wire.pdf
S
Svcmangler
Member
well the car does have an electric cooling fan. but since it is hot after the ignition is on, that would mean it was on all the time.
The vehicle does have a electromatic switch at the radiator that I assume would control the fan.
Platinum
IIRC, that heavy green (+12V) goes to one side of the fan and the "Otter" switch (in the radiator) has the other side at the fan and one to ground. Those should be black, I believe. When the Otter switch closes it supplies the ground leg of the fan circuit.
Disclaimer: This is from memory, haven't worked on that version MGB in a while. These guys: Advance Auto Wire have wiring diagrams for the MGB at every change point in production. Look through and find the year and compare.
Platinum
Just looked thru the schematics and the Otter switch was introduced in '77 from the looks of it. It does supply the ground leg to the fans, that heavy green one should indeed be the voltage supply side for them. The diagram calls the Otter switch a thermostat.
Platinum
Just as we suspected!
SVC - does the electric fan you have now ever come on?
If they do, someone has "modified" the wiring!
Platinum
no the fan does not come on. Now I just have to find where that thermostat switch is
There ~should~ be an Otter switch IN the radiator, at the back top starboard side. Round thing about the diameter of a US quarter-dollar coin. Two male spade connectors. Black wires connected, one goes to a ground point, the other to the fans.
Platinum
no the fan does work if i short it out
Short it how? At the switch? If that's the case, likely the switch is bad. But those green wires to it must have been "added" along the way. There should be NO voltage through the switch, BTW. It should strictly be a grounding device. Voltage should be supplied to the fans with your errant green wire. Have you checked to see if the power is being routed thru the switch? A V.O.M. would be a good thing to have. A 12V test light would work, too.
Svc said:
yes I have that switch and it already has two green wires coming from it. Could this mystery wire plug into the fuse box somehow?
ABSOLUTELY NOT!!! That ~IS~ the fan's "hot" lead. As stated above, the Otter switch is a grounding device. Running +12V thru it is wrong. If the switch body contacts a ground (like if the rubber retainer had a spot where it has been rubbed thru) you could have a dead short. It's a thermocouple device. Bi-metal strip inside.
S
Svcmangler
Member
Yes I shorted it out at the switch, and the fan turned on. You might be right about the switch needing to be replaced. However that still doesn't help with the mystery wire. Would it go to the fuse block? Here is a pic of mine
  • fuse block.pdf
S
Svcmangler
Member
If that is the fans "hot lead" then where does it plug into? If you look at my switch on the fan, it already has two wires coming from it. There is no other place to plug this wire into. Not that I can see anyway
Platinum
Someone has been "creative" in the past, from the looks of it. Can you put a test light on the wires at the switch one at a time to see if one of those is "hot"?
Looking at the diagram, you have it correctly wired, that errant green wire is now a mystery to me as well.
  • 78 mgb.pdf
Mickey Richaud
Late to the party here, but I think you'll find this helpful - scroll down to the '78 model year diagram.
Mickey
W Mystery purple wire Triumph 5
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
J TR2/3/3A TR3 gas tank mystery Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
AN6-TX Application of Marvel Mystery Oil Spridgets 8
J TR2/3/3A Mystery Wood Triumph 7
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
Y MGB A bellhousing mystery.... MG 3
P Mystery leftover BJ7 Pieces Austin Healey 18
warwick-steve Mystery Rattle Austin Healey 21
K Off Topic Mystery Windshield Brackets or ?? Triumph 6
warwick-steve Misfire mystery Austin Healey 28
ckeithjordan TR2/3/3A TR Mystery Thingy Triumph 13
S Marvel Mystery Oil Spridgets 7
D mystery Friday... Austin Healey 5
D mystery of the day... pedal block? Austin Healey 5
HighAltitudeTR3 TR2/3/3A Mystery Bracket Triumph 23
D TR4/4A water pump mystery hole Triumph 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
T TR2/3/3A Another Mystery Part Triumph 8
R TR2/3/3A Mystery part? Triumph 10
T 100-6 LHD/RHD mystery Austin Healey 7
