TR6 Horn Mystery
Sixpack
Bronze
My 73 TR6 air horns go off when the ignition is activated, but the battery is low. If I charge the battery, they act like they are supposed to. Has anyone had a similar issue where their horns go off when you turn on your ignition and the battery is low?
LarryK
Sixpack you might get an answer from the Triumph forum below. This is basically for help using he forums. I have never seen your problem on my Triumphs. Might check your grounds to engine and chassis.
Sixpack
Sixpack
Bronze
Thanks Obi Wan. Been wrenching for 40+ starting out on British sportscars. I know a low battery can cause similar issues in modern vehicles, especially those with alarms, but not a TR. Plenty of other electrical hocus pocus issues but not this one. I saw this links and appreciate your sending them.
Sarastro
I can't think of any reason why the horn should stay on just because the battery is low. There is nothing in the circuit that would do this.
Probably you just moved something coincidentally when hooking up a charger. Take a good look at the wiring at the horn relay and in the steering column. I'll bet that the wire in the column is shorting to ground somewhere. It's also possible that the horn relay is sticking, but that's less likely.
P TR6 Horn issue 1974 TR6 Triumph 5
P TR6 TR6 Horn Relay Problems Triumph 8
T TR6 TR6 Horn Triumph 20
W TR6 tr6 horn aftermarket Triumph 1
W TR6 tr6 horn button Triumph 2
W TR6 TR6 Horn only works when key is off Triumph 27
T TR5/TR250 TR6 Horn Relay Triumph 1
W TR6 tr6 horn wiring Triumph 1
C TR6 TR6 horn repair Triumph 1
sundown TR6 tr6 horn Triumph 4
W TR6 horn blows tr6 Triumph 4
I TR6 TR6 horn help please Triumph 13
I TR6 TR6 horn help please Triumph 2
mabbott TR6 TR6 horn relay? Triumph 1
C TR6 69-TR6 horn problem Triumph 4
wangdango TR6 '76 tr6 horn push Triumph 1
B TR6 TR6 horn button intsall Triumph 11
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
I TR6 TR6 phantom horn Triumph 2
T TR6 TR6 horn button Triumph 34
2wrench TR6 Help with horn removal '74 TR6 Triumph 6
mrv8q TR6 TR6 horn button rebuild Triumph 4
S TR6 1975 TR6 no horn Triumph 5
Brosky TR6 Horn problem with TR6 Triumph 12
B TR6 Horn Assembly Question 74 TR6 Triumph 2
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
