TR6 TR6 Horn Relay Problems
phil56
I have searched through many forums and have been unable to find anyone with a similar problem. I am on my third new horn relay from Moss and have been unable to get the horn to work with the new relay. The horn works fine with the old mechanical relay. I have transferred the four wires over from the old relay to the same connectors on the new relay and have double checked the wiring against the wiring diagram. For the first two relays I disconnected the battery and transferred the wires, then reconnected the battery. When I pressed the horn button, the horn came on and stayed on even after I released the horn button. I had to disconnect the battery. After that, when I reconnected the battery, the horn would only click when I pressed the horn button. For the third relay, I left the battery connected, connected the purple wire with two connectors to W1 and C2. When I connected the PY wire to C1, without the PB wire to the horn button connected, the horn sounded. My car is a 1973 TR6.
I notice that for the 70 - 71 models with A type overdrive, this same relay is used for the overdrive, but connected differently from the horn relay. As a horn relay, C1 is used for the load side, while for the overdrive, C2 is used for the load side. For a mechanical relay, I dont think this makes any difference. However, I am wondering if the new relay is solid state and it makes a difference which way around C1 and C2 are connected.
Any help someone can give me would be appreciated. Thanks
Sarastro
What relay, precisely, did you get? I've never heard of a commercially made electronic relay, although it is possible to make one (I have). By "mechanical relay" I assume you mean the standard type of electromechanical relay, yes?
If it's an electronic relay, the connections almost certainly will matter, but the manufacturer should have provided information on hooking it up. For an electromechanical relay, the switch connections are interchangeable. So are the coil connections.
The only horn relay I found in the Moss catalog is the metal-box thingy used in all kinds of TRs. That's not electronic. I had one in my TR4A, and I removed it after it shorted the +12V to the case, blowing a fuse. Not what I'd call a finely made component.
You can use an ordinary automotive relay if it doesn't have to look original. That's what I have.
P
phil56
Thank you for the reply. Yes, I mean electromechanical, referring to the old relay. I am trying to change the relay because, when I got the car, the relay in it did not work and I took it apart and fixed it as a temporary measure, and the box has a lot of surface corrosion and looks awful.
I think we are talking about the same relay. The new relay I have is Moss part number 542-170, which lists in the Moss TR250 and TR6 catalogue to be used for the A type overdrive and the horn. On the Moss web site, it shows this relay is used for a long list of Triumph, MGB, Jaguar and Austin Healey applications. Moss did not provide any instructions for connecting it, so I am going by the wiring diagrams. I am suspicious that this new relay is electronic. With no power applied to the relay, I get conductivity between C1 and C2. It is all over the place between 3 ohms and 100 ohms and depends which way I measure the resistance. An electromechanical relay would just have open points, no conductivity. I think probably it should be connected as shown for the overdrive, but I dont want to do this and smoke test it, and have to pay for another relay. On the other hand, if it shows that it is OK to connect it with C1 and C2 reversed for the overdrive relay, then I should be able to connect it this way for the horn? Perhaps I should go back to Moss and find out if it is electronic.
Again, thanks for your reply and any other insight you might be able to think off.
Madflyer
Not trying to Speak badly but you got it from Moss.
A story to tell ; MyTR6 1973 heater cable broke so I did off and on by hand until a club member was ordering parts ( MOSS ) I ask him to add a new cable for me. It worked a few times then failed! it just a steel wire how hard could it be. so by hand for a few years . so I order a cable for BPNW two week ago and replaced it. To end; the wire was several sizes thinner on the Moss unit and the set screw would not hold the wire. With the stories from other club members I could go on. If you are not looking OEM get a relay from auto parts store or just clean and paint yours I only have one spare so can not help there. MF
P
phil56
Thank you for the comment. This TR6 is my third restoration in the past 10 years. The previous two were Fords. I have encountered some quality control issues with Moss parts that are very similar to issues I encountered with similar parts for the Fords. If I figure this relay problem out I will post the results.
Madflyer
I do not think it is always the parts suppliers ( Moss, TRF etc.) it's where they get there after market parts China Mexico . The UK for parts still has best quality
poolboy
Do you have "TRIUMPH TR250-TR6 ELECTRICAL MAINTENANCE HANDBOOK" by Dan Masters ?
He has some helpful information about horns and relays in his most invaluable book.
A real timesaver:
Sarastro
I really doubt that you have an electronic relay. Your description makes me think that the contacts are just not closing or opening properly.
If you're not concerned about original appearance, you could use something like this:
P
phil56
Thank you everyone for your comments. Sometimes it takes a bit of conversation to get me thinking. I found a Moss video on youtube about how a relay works. It is electromechanical, I can hear a clicking sound when I apply power to the W connector lugs. The contacts are not doing what they are supposed to be doing according to the video. This is the third relay in a row that Moss has sent me that is faulty. Looks like they got a bad batch that they have not tested. To me, it is one thing to trouble shoot parts that are in the car to find out if they are working properly, but I dont think we should have to be trouble shooting new parts. We should be able to install them and have them work. If suppliers want to get their parts from the lowest cost manufacturer, that is fine, but I think that they should be doing some quality control and not just passing through poorly made parts to the consumer. Just my humble opinion.
T TR5/TR250 TR6 Horn Relay Triumph 1
mabbott TR6 TR6 horn relay? Triumph 1
P TR6 Horn issue 1974 TR6 Triumph 5
Sixpack TR6 Horn Mystery Triumph 3
T TR6 TR6 Horn Triumph 20
W TR6 tr6 horn aftermarket Triumph 1
W TR6 tr6 horn button Triumph 2
W TR6 TR6 Horn only works when key is off Triumph 27
W TR6 tr6 horn wiring Triumph 1
C TR6 TR6 horn repair Triumph 1
sundown TR6 tr6 horn Triumph 4
W TR6 horn blows tr6 Triumph 4
I TR6 TR6 horn help please Triumph 13
I TR6 TR6 horn help please Triumph 2
C TR6 69-TR6 horn problem Triumph 4
wangdango TR6 '76 tr6 horn push Triumph 1
B TR6 TR6 horn button intsall Triumph 11
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
I TR6 TR6 phantom horn Triumph 2
T TR6 TR6 horn button Triumph 34
2wrench TR6 Help with horn removal '74 TR6 Triumph 6
mrv8q TR6 TR6 horn button rebuild Triumph 4
S TR6 1975 TR6 no horn Triumph 5
Brosky TR6 Horn problem with TR6 Triumph 12
B TR6 Horn Assembly Question 74 TR6 Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 4
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
