TR2/3/3A Mystery knocking sounds at front wheel
JAJohn
Member
Bronze
Help! My revived 62 TR3 went on its longest drive yet, about 10 miles, but after about 6 miles a mystery sound happened while running. A non-metallic thumping/banging, getting louder, sounded like at the driver's side front wheel. Increased in speed and volume as the car speed increased, but stopped with applicaton of brakes. Absolutely no effect on engine, transmission/ clutch. After a while, it stopped mostly, except when turning right or left.
Recently had brakes/clutch rebuilt at great cost. The car sat for 40 years. Maybe wheel bearing failing? Brake caliper not tightened up?
Gliderman8
A couple of years ago I had a “mystery knock” in the front wheel of my TR6.
It turned out to be a bolt that held the brake rotor had worked itself loose because a locking tab was not bent up preventing the bolt from loosening. Just something to check.
Sarastro
My guess is also that something is loose in the wheel/brake assembly. Best thing is to jack it up and take a good look. Lots of things can cause this type of phenomena, so it's hard for any of us to do more than guess.
Don't discount trivialities. A little while ago, right after getting new tires, my modern car developed a thump in one wheel. I started to panic, assuming that one of my new tires was bad. I took a good look and found a palm-tree seed stuck in the tread. Picked it out, and all was well afterward.
CJD
Are you running wires or discs?
A wheel bearing would make a rumbling noise, so you can count it out at least.
bobhustead
That it stops with application of the brakes implies something in the brake system. Rotor not snug to hub, loose pads, loose caliper, loose caliper mounting plate. If you can't find it by simple inspection, you will probably need to disasssemble the whole corner until you do find it. Could be very unsafe
Bob
J
JAJohn
Member
Bronze
this car has solid wheels. My first tr years ago had wires, and i heard a similsr sound then when about half the wires on one whrel broke.
sp53
Sounds too noisy for the pressure valve not to be applying some pressure on the brake pads, but that could be it because you say it goes away when you apply the brake. Maybe the brake pads are knocking around on the roto. But again probably something lose.
Steve
J
JAJohn
Member
Bronze
Mystery solved! The knocking sound was in fact the entire wheel, loose on the lug nuts. Apparently the large expense of rebuilding the hydraulics brakes and clutch didn't include tightening the lug nuts on the wheels. All of them around the car were about finger-tight.
Gliderman8
Man you dodged a bullet. Glad you found the cause.
mctriumph
The garage should be responsible for the costs of studs and a replacement wheel.They owe you this, at least, for
the damages they incurred from their negligence.
Mad dog
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
J TR2/3/3A TR3 gas tank mystery Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
S MGB mystery wire MG 32
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
AN6-TX Application of Marvel Mystery Oil Spridgets 8
J TR2/3/3A Mystery Wood Triumph 7
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
Y MGB A bellhousing mystery.... MG 3
P Mystery leftover BJ7 Pieces Austin Healey 18
warwick-steve Mystery Rattle Austin Healey 21
K Off Topic Mystery Windshield Brackets or ?? Triumph 6
warwick-steve Misfire mystery Austin Healey 28
ckeithjordan TR2/3/3A TR Mystery Thingy Triumph 13
S Marvel Mystery Oil Spridgets 7
D mystery Friday... Austin Healey 5
D mystery of the day... pedal block? Austin Healey 5
HighAltitudeTR3 TR2/3/3A Mystery Bracket Triumph 23
D TR4/4A water pump mystery hole Triumph 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
T TR2/3/3A Another Mystery Part Triumph 8
R TR2/3/3A Mystery part? Triumph 10
T 100-6 LHD/RHD mystery Austin Healey 7
T TR2/3/3A Mystery Heel Panel Holes? Triumph 6
