TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not
Got_All_4
It's been a long time coming. Last December I started on a overdrive install and a steering column rebuild and along with a few other problems I found the car is drivable now. Installed a modern radio over the weekend and before I buttoned it up by installing the Kidney style speaker panels I tested all the lights, turn signals and 4way flashers. All worked as they should. Went to take the car for a drive and no lights at all in the rear of the car. No backup, running lights, side markers or stop lights. Also the fuel gauge is not working now. The lights in the front of the car are all fine. Did some tracing tonight and there is 10.6 volts coming out of the voltage stabilizer. Power at the 3 way connections from the turn switch. Even out of the brake switch. Just nothing makes it back to the rear of the car. Checked fuses firsts and good. Any ideas where to go next?
Mickey Richaud
Mornin'!
My guess would be a ground issue, especially since the trouble is all at the rear. Maybe a common ground connection for all the lights has been disturbed...
charleyf
When these cars sit for awhile the fuse ends can get corroded and the contacts and fuse ends need to be cleaned. Hopefully you checked both ends of the fuses for power not just the fuse.
Charley
Got_All_4
Got_All_4
I did and pulled out each fuse and checked them individually too. There was a TR6 in one of my customers today being restored and I looked at the harness under the dash. (The dash was out). I believe my 250 has the same connection where the rear harness plugs into the front section. I may have rolled over it working underneath and pulled it out. That may explain why everything in the rear quit working at the same time. I'll check later tonight.
Got_All_4
Got_All_4
Wala! That's what it was. Must have been vibration over the years and when I push the main harness back into one of the metal tabs I probably pulled on it and pulled it out of the terminal. Never felt anything that's why I say vibration over the years working it's way out. Zip tied it so this doesn't happen again.
charleyf
Congratulations.
Charley
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
H Re: electrical short wiring damage Spridgets 11
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
S TR4/4A Electrical wiring tips Triumph 2
KVH TR4/4A Stumped on Electrical Wiring--TR4A Triumph 7
B 59 electrical wiring Triumph 2
77MidgetMkIV question on electrical gauge wiring Spridgets 14
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
R Electric fuel pump wiring Spridgets 4
B TR4/4A Wiring Harness Triumph 6
R Wiring ??'s Spridgets 17
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
M TR6 Fuse box wiring mystery Triumph 9
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A 1954 TR-2 O.D. Wiring Triumph 9
TomMull Dash wiring Plus 2 S Lotus 16
MadRiver BT7 Wiring Diagram Austin Healey 4
R TR2/3/3A Replace wiring harness in steering column Triumph 61
