TR4/4A Electrical wiring tips
shoopal
Hi all
I would like to pass along some interesting information relating to TR4 and 4A wiring. I have an early 65 4A #CT55091. I bought a new harness many years ago and now I am installing it.
Comparing the wiring diagram from the manual and the one published by Dan Masters, I have discovered some differences that may raise questions.
TR Manual: Horn powered from starter solenoid, no relay
6 lamps powered from rheostat
No wiring for flasher repeater in sidelamps
No provision for two speed wiper motor (ask me for exact wiring)
I had to run another wire from wiper motor B/G to terminal 6 on switch
Mix-up in L.H. and R.H. description of direction indicator (#41,42 and 47,48)
Masters:
Horn powered from voltage regulator terminal A1 with relay
8 lamps powered from rheostat (not sure what the other two are)
The Masters TR4 diagram more closely fits my 4A in parts, and not in other parts.
There may be other discrepencies since I still have to finish tail direction and brake and license lamps.
Finally, using my Fluke meter to chase continuity I sometimes had problems with oxidized contacts and bad connections. The ignition warning lamp was the poster case of a bad contact and sent me up the wall.
Hope this helps someone
Al Shoop
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
H Re: electrical short wiring damage Spridgets 11
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
KVH TR4/4A Stumped on Electrical Wiring--TR4A Triumph 7
B 59 electrical wiring Triumph 2
77MidgetMkIV question on electrical gauge wiring Spridgets 14
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
D TR2/3/3A TR3A electrical issues Triumph 2
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
R TR2/3/3A Early TR3 electrical system Triumph 12
K TR2/3/3A More electrical....the Starter? Triumph 8
K TR2/3/3A More electrical....the Starter? Triumph 5
B TR2/3/3A Electrical Problem Triumph 13
T TR2/3/3A electrical oddity Triumph 7
