TR6 72 TR6 electrical snafu
Tomu
Hey folks
recently replaced my starter with a gear reduction starter. It is a wosp performance starter and the connection that connects to the Solenoid had 2 wires coming out. I of course hooked up to the one which contained a diode. Needless to say it didn’t work so I switched to the other wire and poof! Started right up. This brings me to my next problem. I no longer have turn signals, gas gauge, temp gauge, horn...looking at my wiring diagram it appears everything that doesn’t work is on one fuse. I replaced the fuses and still have nothing. This car has been great electrically, what did I do! The one wire that connects to the starter also appears to connect to the alternator and to the affected equipment. Possibly that wire is broken ? Thanks in advance for any help!
poolboy
Unless someone took some liberties with the wiring all those things mentioned would NOT have been on the same fuse,..so the problem is up stream of the fuses.
Check out everything electrical...maybe there are more electrical components affected...things like head lights, windshield wipers and more., then using this schematic trace back to a common connection.
http://www.advanceautowire.com/schematics.htm
T
Tomu
Thanks for the help! The wiring diagram you sent is easier to read in color. One of these things that never game me a problem! Thanks again
steveg
These wiring diagrams are a great service! I got mine printed out 11 x 17 and laminated.
After years of using color wiring diagrams for the Healey, can't recommend them too highly. Every DIY owner should have one!
Madflyer
There is a horn relay next to fuses brown wire horn button makes contact to ground. If the fuse is good and the fuse holder is good you lost your grounding. Next to the battery leads to starter is a tab firewall flat area that a black wire slides on to easily slip off. light purple wires are dash lights at fuse block. test volts to ground at fuse if you do not have a tester a 12 volt bulb with wires for contact . A tail light socket will work for parts. If you still have the stock pos. battery lead that brown wire comes from the connector in the middle of that red battery cable Note I replaced my fuse block with the new blade fuses and some glow when blown. any auto parts stores . Madflyer
bash TR6 TR6 electrical help Triumph 11
T TR6 Electrical Problem with TR6 Triumph 11
hondo402000 TR6 TR6 Amp Meter question Electrical guru needed Triumph 4
B TR6 Need guidance on TR6 electrical issue Triumph 7
Tim Tucker TR6 TR6 Electrical Question/Suggestions Triumph 11
T TR6 Fry a TR6 electrical system in these easy steps Triumph 16
hondo402000 TR6 TR6 electrical problem continue Triumph 23
hondo402000 TR6 TR6 towed on Sat night, electrical problem Triumph 9
TR6Stuart TR6 TR6 Electrical Problem Triumph 10
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
