Tim Tucker
HI guys.
I have had my TR6 for just over a year now. Very little electrical worked correctly when bought: mis-wired or bad sockets mostly. Everything 'basically' works now and my main isuue is: the IGN light that won't go off!
I installed a new battery when bought and repaired the Lucas 17acr alternator (new regulator and 1 diode). I have driven it without having to jump it off ever since.
Last Friday I replaced the factory AMMETER with my Fluke. Here is what I got:
Lights ON (high beam):
700 RPM (per electronic tach) – discharge condition
1200 RPM – 0 amp condition
above 1200 – charge condition
Lights OFF (performed after lights on test-slight discharge of battery may have occurred):
700 RPM – 2A charge
over 700 RPM – more charge
Voltage measured at Battery:
12.2 VDC and dropping with lights ON(car at idle);
12.4 VDC and rising with lights ON(1200 rpm);
12.84 VDC with lights off(idle)
TEST #2 What voltage does the IGN light see?
Fluke voltmeter hooked as shown (red to alternator, black to the white wires on the back of the ignition switch).
Reading at idle(700): -.2 to -.5 VDC very bouncy, idiot light barely lit
Reading as RPMs increase(above 1200): +3VDC, idiot light bright
Thanks if you took the time to read this post...Smile Any advice would be welcomed. I realize the best approach would be to replace the Lucas alternator. I just don't fully understand why the IGN light is lit. Is it the regulator that is causing this? I have checked the battery voltage several times over the year and it is always good.
Last question:
Is there a trick to getting the knob off of the dash illumination rheostat? I don't seem to find a button to depress.
Thanks,
Tim
700 RPM – 2A charge
Last question:
Thanks,
Tim
