General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch
KVH
I just installed a new light switch in my steering column. I feel the switch is improperly manufactured. The blue/white wire protrudes into the shaft space and I can feel the signal "trip rib" on the shaft lightly brushing that wire as I rotate the shaft, right where the wire insulation ends. I've disassembled and reassembled four times and if I bend that wire and connector any further I'm concerned I'll ruin the light switch solder plate.
So, for the electrical experts here, would it make any difference if my steering shaft occasionally brushed past that wire as I was steering? I just don't understand "electrics" enough to know what it might mean to add any kind of intermittent or fleeting "negative current" to that circuit. Do I need to just get bold and bend that connection way back? Thanks guys!
PS I'm getting frustrated by the increasing number of defective parts I'm receiving. This one clearly should have been manufactured with the screw mounting holes forward an eighth of an inch. My shaft bushings were another story of bad parts. Anyway . . .
Andrew Mace
You've described yet another reason why I seek out NOS or excellent used parts whenever possible. I personally would NOT want to see a powered wire ever contacting the steering column; that's pretty much how Lucas manufactures replacement smoke. :( It does, though, sound as if the location of the mounting screw holes is the fault here. Might there be a way to ever so slightly "slot" the holes in the column so that the switch might come away from the column just that wee bit? I personally hate to modify original parts in order to accommodate bad repro parts, but there's that whole spark / smoke / smell / possible fire thing, so....
KVH
KVH
OK, Iā€™ll take your advice. Off it all comes again. Iā€™ll see if I can expand those holes.
Rut MGB 62-67 upper MGB steering shaft MG 3
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
Popeye TR4/4A Steering shaft rebuild Triumph 3
Rut TR4/4A steering shaft/nut thread size Triumph 5
steveg Steering shaft repair Austin Healey 1
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
JFS Wedge Steering shaft / fire wall grommet Triumph 2
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
R BJ7 Steering Gear and Idler Rock shaft Austin Healey 4
Zitch Steering shaft Thread Triumph 22
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
T TR4/4A TR4a steering shaft play Triumph 21
B About the steering shaft brackets Triumph 2
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
J Shorten the steering shaft ? Austin Healey 4
dklawson Spitfire Spitfire Steering Shaft Coupling Construction Triumph 9
CraigLandrum TR2/3/3A TR3A Steering Shaft stator tube??? Triumph 26
M TR6 play in upper part of steering shaft tr6? Triumph 2
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
